Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: sound works, picture is very dark
You have to be specific when asking a question please. as you dont mention its a flodable LCD screen TV as I had to look it up. your problem is in the backlite circuit. if your a tech, you should have no problem finding this fault but could be a little trick if your not as your going to need to know how a back light circuit works, the parts in the circuit and know how to use a multimeter. Good Luck
SOURCE: My haier tv is not working
This classic a HV supply problem. The possible culpits are deffective flyback transformer, Hv rectifier or the horizontal output transistor
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
SOURCE: How do I replace the backlight on a Samsung
this normaly find on electronics shops, but normaly better to go repair store, for full checkup.
SOURCE: I have sound but not picture on a Haier plasma tv
Hi my name is Roety,
I can help you with your issue ,
These Haier TVs go bad and I always install the repair kit part #?TV-3940-01
It includes the scan boards and an upgraded IC .
I can not find any kits in stock, but I know there some available online if you search or call a few places.
Mat electronics or sears parts direct may have some.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Testimonial: "this is very helpful,I will try it and let you know. NAVARRO"
