Question about Manitowoc Kitchen Appliances - Others
SOURCE: replacement ice maker
Sounds like you may have gotten a wrong kit, or a mislabled kit. Take it back and ask the salesperson to correct the error. Ask them for some advice if they try to say it is the right one. They made a profit on the sale so they need to make it right with you.
If you get nowhere, which is likely to happen, post me back and I can help you come down legal on them.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
SOURCE: I have a manitowoc QY0424A ice maker and the water
Turn back the pressure on the water going into your home and or if there is an adjuster on the back of the fridge set it for 1/2 less.
Are you in a house or a flat?
Posted on Mar 20, 2010
SOURCE: i have a model qd0452a manitowoc and it will not
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Posted on Dec 11, 2010
SOURCE: manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
SOURCE: Manitowoc Ice Maching. Model B400.
that is a 400 lb. per 24 hours machine. can you explain the problem in further detail.
Posted on Sep 18, 2011
Oct 28, 2016 | Manitowoc Refrigerators
Aug 25, 2015 | Kitchen Appliances - Others
Aug 31, 2014 | Manitowoc SY0324A S Series Ice Maker...
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Jul 27, 2014 | Manitowoc B Style Ice Storage Bin 22 Ice...
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
Sep 11, 2013 | Manitowoc SY0454A S Series Ice Maker...
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
Nov 29, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
Mar 29, 2009 | Manitowoc Koolaire Undercounter Freezer...
48 people viewed this question
