Question about Home
Put new batteries in Howard Miller battery operated wall clock now hands have stopped working. What's my problem?
Posted by Barbara Sporman on
Andrew Taylor
    Top Expert:
  • Home Master
  • 33,433 Answers
Batteries were put in the wrong way?
Contacts are not clean?
Batteries were not fresh?
Clock is broken?
Posted on Mar 23, 2017
Instructions for setting howard miller clock 645-553
Google (howard miller)(645-553)(manual) without parens.
Jul 17, 2018 | Home
Just bought a Howard Miller 620-160 wall clock. The pendulum is not swinging! What is wrong?
First thing to check is for locks that are put in when shipping so that it wont be damaged. If it is battery powered, check the battery.
Apr 02, 2016 | Watches
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Apr 14, 2010 | Seiko Mantel Clock
Changed battery and now pendulum wont swing. Clock doesn't operate at all. All was fine until I changed the battery.
Give the pendulum a shove and do it every time you pass the clock. I got mine going from swinging for just 20 seconds to working permanently, at least until the next battery change.
Jul 07, 2009 | Howard Miller 645-627 Clock Radio
Home Logo
150 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
