SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 – Fax 01628 776345 - Spares Email is [email protected]
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
SOURCE: loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
SOURCE: oven door handle is loose. Don't know how to get to it.
Hi, Get me a model# and I can look this up for you.
Thanks
Vic
