I have an Ideal Logic+ Combi C30 fitted 2 months ago. I also have a Hive thermostat and Receiver. I have had no problems until 3-4 days ago when the boiler failed to fire up for central heating. We have hot water on demand no problem. The screen on the face of the boiler shows a message 'room stat or timer off'. But the thermostat is working as it should and seems OK. Any fixes?
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Posted on Feb 05, 2018
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Posted on May 29, 2009
SOURCE: Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Posted on Dec 03, 2009
SOURCE: I have a Heatslave 12/14 oil-fired combi boiler
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Posted on Jun 15, 2011
Dec 30, 2017 | Water Heaters
Dec 31, 2016 | Water Water Heaters
Jul 02, 2016 | Water Heaters
Oct 09, 2015 | Water Water Heaters
Dec 13, 2014 | Water Heaters
Oct 15, 2009 | Water Heaters
Oct 13, 2009 | Water Heaters
Sep 11, 2009 | Water Heaters
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
226 people viewed this question
