I have a LG TROMM dryer model DLE7177RM and the it takes a long time to dry. under the processing display is reads DRY and Cooling at the same time. Any ideas how to reset the dryer?
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
Sorry to read about your problem, I hope this helps you out.
yes it can, if you ever have issues, you can put in a booster fan for dryers.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
Ah you unhooked it from the wall, but did you go outside and see if air flow was adequate outside. Quite often flexable hoses and duct work get plugged with lint. If that is the case be glad your dryer had pleanty of safetys. If you start it briefly with the hose disconnected, do you get the dry light flashings? Metal duct work all the way outside is best.
Hi, I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
