From the GM 2005 Chevrolet Equinox Service Manual:
Remove Spoiler:
1. Open the liftgate
2. Remove the liftgate upper interior trim panel to expose the center bolt
3. Remove the spoiler to liftgate bolts (3)
4. Disconnect the stop lamp harness
5. Disconnect the rear washer hose
6. Lift the spoiler to disengage the locating retainers and remove the spoiler from the liftgate
Remove the high mounted stop lamp assembly:
1. Remove the spoiler to high mounted stop lamp screws
2. Disconnect the electrical connector
3. Disconnect the washer hose
4. Remove the stop lamp from the spoiler
Install the high mounted stop lamp assembly:
1. Position the stop lamp assembly to the spoiler
2. Connect the washer hose
3. Connect the electrical connector
4. Install the spoiler to high mounted stop lamp screws, tighten to 2 N-m (18 lb in)
Install Spoiler:
1. Position spoiler loosely over the liftgate
2. Connect the rear washer hose
3. Connect the stop lamp harness
4.Push down the spoiler to the liftgate to secure the locking tab retainers
5. Install the spoiler to liftgate bolts; tighten to 2 N-m (18 lb in)
6. Install the liftgate upper interior trim panel
7. Close liftgate
SOURCE: emergency brake light is on all the time without
check your fluid level on the master brake cylinder resevoir(RH side to the rear of the engine compartment mounted to a large circular metal). When the fluid is low, this light will remain on. If the levels are fine, might be a possible damaged Ebrake switch or air in the system. Hopefully this helps
SOURCE: abs and traction control lights on 2005 equinox
check connections at all wheel speed sensors or faulty sensor/tone rings
SOURCE: 2005 Chevy Trailblazer no brake lights, but third
The body mounted brake lights, are on a different fuse than the upper light. Check fuse #12 a 25amp fuse in the fuse block under the hood on
the left fender. The upper light fuse #16 a 10amp fuse in the rear fuse
block, under the left side of the back seat. Hope this helps.
SOURCE: 2005 chevy equinox brake lights stay on even after
With the vehicle off unplug electrical connector on master cylinder. If lite is still on your right. You can usually see where this circuit grounds?shorts out.
If lite goes off... Now you have a little bit of a head ache.
For safety reasons double check for leaks. If the system has no leaks you have to back probe that circuit to find that short.
SOURCE: my brake lights are not
Check fuses if you haven't already. They are not all on the same fuse. There may also be an inline fuse. Check your bulbs. Both break lights are on the same circuit. It's possible both blew together.
