Question about Westinghouse WST3501 Microwave Oven
Clock how to get the clock back to work
Posted by llggii on
William Miller
  • Westinghouse Master
  • 9,179 Answers
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
Posted on Nov 22, 2007
How do i set the clock on my microwave
Try unplugging from power. Wait a bit. Plug back in. Push clock button and see if that works. Good luck.
Mar 03, 2015 | Rival Em720cwapm 0. Cu Ft Microwave Oven
The digital clock/timer on my stove has basically quit working. The timer keeps setting to 59 minutes and beeping all day and all night and I cannot set it back to clock after the buzzer goes off. How do...
Your membrane keypad is shorted.
Whether it's available as a separate part, assembly, or if you have to order a whole controller is determined by the model number, which you did not mention.
You can find handy exploded views and order parts by model number here.
May 25, 2011 | Microwave Ovens
Hi, My microwave oven stopped working after I came home from four days of vacation. The digital clock works. What could be the problem? The turn table does not work. Is there any danger opening back of...
if the clock is working then the fuse is fine. if the fuse goes bad the unit would be completly dead. no their is danger removing back panel. as you said make sure the unit is inplugged., however some electrical parts inside hold a charge until discharged.the board could be bad, the door latch or switches could be bad.
Sep 19, 2009 | Sharp Microwave Ovens
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
I want to see the clock on my microwave amana rcs820bl
Set the clock?
Normally one of these combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please write back if you need further help.
Sep 07, 2008 | Amana Microwave Ovens
Setting clock
In most brands, you set the clock by one of these combinations of key presses:
Apr 22, 2008 | Microwave Ovens
Setting the clock on Sharp Microwave Oven
Normally it's
Clock > time numbers > Clock
or
Clock > time numbers > Start
Sometimes it's
Clock > (1 or 2) > time numbers > Clock
or
Clock > (1 or 2) > time numbers > Start
If this doesn't work, please reply back with your model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Microwave Ovens
Setting the time on Sharp microovens.
Normally it's
or
Sometimes it's
or
Setting time on sharp microwave
Normally it's
or
Sometimes it's
or
Microwave Ovens Logo
412 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
john h
ray gallant
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
