Question about Uniworld Food Mixers
How do i adjust the safety guide on my uniworld sm-10 mixer. It is loose and so the mixer will not run unless we hold it with rubber bands. All parts are there
Posted by Heidi Orr on
1 Related Answer
Mister Danger
  • 5631 Answers
SOURCE: I have a Uniworld UPM-20E commercial mixer. I bought used from another baker and it was working when I bought it.
Electric devices get damaged sometimes by internal corrosion even if you don't use them. If you have the technical knowledge, take apart the control board or control panel, probably you've got some contact problem. you might be able repair it by cleaning or maybe you might need some part to replace.
If you don't have real knowledge repairing this kind of an appliance, my best advice: take it to a repair service.
Some time ago I tried to do a similar job with my home mixer and had to take pieces in a shoebox to a repair service ; I took it apart, cleaned contacts bur couldn't assemble it againbecause after taking it apat, couldn't assemble it again
Posted on Aug 20, 2015
All speeds work but all too fast
the mixing speed was attained by the use of a potentiometer ( variable resistor ) that would have controlled the power into the board or from the board to the motor
it would be under the speed setting knob
maybe the resistor in use is not the right one and is not reducing the voltage sufficiently to do the job
Nov 08, 2015 | KitchenAid K45SS Classic Stand Mixer
Aug 20, 2015 | Uniworld UPM-20E 20QT Commercial Planetary...
How do I find someone who can supply me with Uniworld mixer parts.
By the time you get these, postage and shipping etc, you may as well buy a cheaper handmixer.
Dec 07, 2014 | Uniworld UPM-30E 30 Quart Mixer With Guard...
Need manual and part number for brushes on a Kitchenaid RRK90
Well first thing; here is the link to the KitchenAid site where your parts list can be found.
http://www.kitchenaid.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208212057.pdf
Next, the parts list will tell you what the part number is for the brushes and all the parts that make up the brush assembly. If you need to replace any part other than the brushes you will need to do a full tear down to do that. Also; remember that there are four different ways to replace the brushes but only one way will work. You need to be very careful to remember which way the old brushes come out, there is a beveled edge on one side of the brushes and the new brushes need to go back the exact same way or they will not reach the commutator on the armature and the mixer will not work until the brushes make that contact with the armature.
Lastly the reason that your mixer gets out of time is that over time, 8-10 years of use, the nuts on the speed control switch that hold the three timing screws in place simply get loose due to vibration and the screws can rotate in or out. Some times the screws vibrate loose and the mixer just will not turn on next time the mixer is used. Peeps then think it's broke and will not work so they sell it for parts and by a new mixer. When the only thing they need to fix it is a Phillips screwdriver , a small 3/8th open box wrench and about 20 minutes time to fix it.
Anyway I hope that this helped to answer your question. Please let us know if it helped and if not let me know and I'll try to help fixya.
Aug 31, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Can I Have a wireing diagram for Uniworld m20e year 2012
hi, can i have a wire diagram for a M20E please i changed the contractor but still not working i guess misplace some wire?
thank you
Aug 18, 2014 | Uniworld Foodservice Equipment Upm-M20e...
Mixer does not turn on.
Still have the problem with this mixer not turning on? LEt me know if you have checked the breaker and the cord (Check for a loose or disconnected plug end -- Should have the 3 Prong ground attached. This is often the case, but then the 2nd problem is that one of the SAFETY Switches is not engaged, not allowing the mixer to be turned on -- it's a matter of checking each of these symptoms systematically to know for sure. Let me know if I can help.
Nov 30, 2013 | Uniworld UPM10E Stand Mixer
Missing the bowl raising handle
Check your manual that came with it. There's usually a customer service number. Things like that usually must be ordered dirctly from the manufacturer.
Jan 01, 2013 | Uniworld Commercial Kitchen Mixer 20 Quart
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Mixer runs but blades slip when you add the food
Hi Victoria. There is internal damage in your mixer's transmission. The unit needs to be serviced, and repaired.
Here is something you can try on your own. Unplug the mixer, remove the single screw that holds the silver band. There are now 4 screws that hold the top cover, remove them, and then the cover.
At the top-front of the mixer you'll find the transmission housing. If this housing is made of plastic, check it carefully for cracks in the housing or near its screw holes. If you find any cracks in this housing, you have found the source of all trouble.
Although Kitchenaid advertises "All metal transmission", the truth is that they use a cheap plastic part to support two of the most important shafts in your mixer. This cheap plastic part will fail at some time when it's mixing cookie or bread dough. When it fails the gears and shafts jump out of position and major damage occurs. This is why it was listed on Craigslist. The previous owner wanted to get rid of it.
Kitchenaid's replacement housing is made of metal. Kinda makes you wonder...
Unless you're mechanically adept, you either need to fix it, or get rid of it. If you're not up to the task of repairing it yourself, then take it to a small appliance repair place for an estimate.
If you're looking for a new mixer, go to consumersaffairs.com and search for a make and model of the mixer you're considering and read the actual customer reviews.
Kitchenaid is not what it once was. Steer clear.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Food Mixers Logo
76 people viewed this question
Top Uniworld Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you an Uniworld Food Mixer Expert? Answer questions, earn points and help others
