Question about Yamaha Boating
Does the impeller on a Yamaha 200 outboard on a left hand motor spin the opposite way as a right hand motor
Posted by Tom findlay on
Steve P
  • Yamaha Master
  • 3,712 Answers
No, the gears in the lower unit are cut to rotate in the "other" direction... If the impeller were to rotate opposite - it would mean the engine had to run backwards... and that does not happen.
Posted on Jul 08, 2017
5 Related Answers
Fame_Guru
Sid
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
Mark L. Roberts Jr.
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
Anonymous
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Larry Maranto
  • 198 Answers
SOURCE: 1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
Posted on May 04, 2010
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
Boat impeller
Undo gearbox bolts,take off trim tab,undo bolt in trim tab cavity,disconnect speedo tube,pull off gearbox. You will see pump housing,undo 4 bolts,pull off housing exposing impeller,there maybe a clip on top of impeller depending on model,pull off clip then impeller.yamaha didn't make outboards in 75
Aug 25, 2014 | Boating
What is the thread on coupler to midshaft left or Right? this is on a yamaha waverunner 1200xl limited
Counter clockwise, it has normal right handed threads. The only part with left handed threads is the pump/impeller shaft.
May 28, 2014 | Yamaha 12V Air Pump
TDA200 Recirculating pump how to replace impellor
There are a number of screws on the pump housing opposite the motor that can be removed to open the pump and expose the impeller. Some pumps have a screw into the center of the shaft that helps keep the impeller from spinning off the shaft. It often is a left handed screw. Once any center screw is removed the cover on the other end of the pump should be removed to expose the end of the motor shaft. This end of the shaft should be held solid with a wrench while the impellor is unscrewed. These threads are usually right handed. The process can be reversed with a new impeller. I hope this helps.
Aug 13, 2011 | Pool & Spa
Hi, I have a waterway executive 48 spa pump and need to replace the seal on the pump shaft. How do I get the impeller off the shaft to access the seal.
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2011 | Pool & Spa
Trying to replace seals for a hayward sump pump and can't remove inpeller
John
May 14, 2011 | Hayward 1 Hp Super Pump Inground Swimming...
How do you remove the impeller to replace the seal?
John
May 07, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
How to remover the impeler in a 2hp Pinnacle?
John
Apr 10, 2011 | Pentair Pinnacle 2 - Hp In Ground Pool...
How do I removie the impeller to renew the seals the pump ie leaking and I have new carbon seals nad I have removed left hand ihread nut at the front of the impeller but it will not come off
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
John
Feb 01, 2011 | Sta Rite Max E Pro 2 Hp Up Rate Energy...
Boating Logo
176 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
