Just for that particular unit. Do a search for : Panosol II master patient log pdf . find your flashing code on the pdf (or if it not on the pdf then you have a newer model and unfortunately this won't help) but if you do see your code, you will look at the last column which is "unlimited" and once you input the corresponding unlimited code on the unit, you will never need another code.
What is the unlimited code for 5710?
6438 Unlimited
Is that for all machines that display a code or just for that specific code. I have a different code flashing.
Just for that particular unit. Do a search for : Panosol II master patient log pdf . find your flashing code on the pdf (or if it not on the pdf then you have a newer model and unfortunately this won’t help) but if you do see your code, you will look at the last column which is “unlimited” and once you input the corresponding unlimited code on the unit, you will never need another code.
