Question about Schlage Locks & Locksmithing
Lost guide for schlage lock do not have tools to take it off to look at back plate
Posted by Jaelyn schulte on
1 Related Answer
Anonymous
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
I can't find the code for my schlage keypad lock. Is there any way to reset my passcode without the original code for the lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Feb 15, 2011 | Schlage Locks & Locksmithing
I lost the manual and i need to reprogram the codes
There is a video on this page, showing how to change codes.
Jan 22, 2011 | Schlage Electronic Lock FE595 Plymouth or...
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I need to change my security code asap but ive lost the manual to the instruction can u please help
Jan 08, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
I lost my instructions to change the keypad password, can you please instruct me on how to change this password?
Jan 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I have a 4 digit schlage keyless lock and want to reprogram it
There's a video for reprogramming it.
Dec 20, 2010 | Schlage Locks & Locksmithing
Instructions needed for changing the keypad combination of a Schlage Camelot Keypad Lock 26D. I lost the instructions. Please advise. Send information to [email protected]
Dec 17, 2010 | Schlage Locks & Locksmithing
How do I delete/add/change the codes? I lost my instructions.
Nov 27, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
.how to reset code push
There's a video that shows you how.
Nov 20, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Locks & Locksmithing Logo
238 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
