Question about Inverter Electronics - Others
I have a KEB Combivert inverter on cnc saw. Getting 161 spindle KEB communication error. Solution??
Posted by Michael Goodson on
2 Related Answers
allinallelec
binay biswas
  • 407 Answers
SOURCE: please i need a programming manual for KEB COMBIVERT F4 INVERTER
For some time internal battery & main battery line disconnect you.so automatic reset.
Posted on May 28, 2012
mntech1
  • 120 Answers
SOURCE: F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Posted on Apr 01, 2014
Apr 01, 2014 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Hi, i have KEB inverter type F4C on my CNC machine... it shows the message L5 (or LS i am not sure about the symbol). The machine showing motor problem and inerter problem. Please advise me on m y ema
LS means Low Speed. The inverter is enabled and is waiting for a command.
Check your speed and direction signals at the inverter to verify if they are active.
Nov 16, 2011 | Inverter KEB COMBIVERT F5
Inverters stops without any error but can buss communicates inverter error!!!
If the inverter is not displaying an error but the CANbus system is showing an error, the problem is with the communications.
Could be a faulty CANbus system, operator in the inverter or possible EMI issue.
Nov 30, 2010 | Inverter KEB COMBIVERT F5
F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
403 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Anon
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
