Cell Phones Logo
p
penny king Posted on Mar 18, 2017
How do i reset my phone as it's stuck in a loop ,it appears and flashes the logo on and off and i can't turn it off or on, its a samsung galaxy s3 gt-19300
Iv'e tried holding down the start, home ad volume up button but nothing is happening
3 Related Answers
Anonymous
  • 32 Answers
  • Posted on Feb 28, 2011
SOURCE: my samsung galaxy 19000 won't
Your phone is getting caught in loop on boot. It needs to be taken to the carrier store and repaired by a professional technician
lfconrad566
Lory Conrad
  • 15 Answers
  • Posted on Jun 04, 2014
SOURCE: I have a samsung galaxy note 10.1 & it is stuck
Will it reboot if you hold the power button in?
shettyvishes
Vishesh Shetty
  • 9 Answers
  • Posted on Nov 12, 2014
SOURCE: heyy.. my phone (sumsung galaxy s3 ) wont go pass the sumsung galaxy s3 gt 19300 screen .. pls help me what should i do .. my phone is like my life.. yours faithally..?
First check if th phn has fallen frm ur hands or updated firmware via 3G or wifi or th sweat gets accumulated on th phn while talking causes it either freeze or touch sensation stops working so plz tell wht has actually happened nd also wht have u tried nd wht exactly shows on th screen
Testimonial: "no its hasn't fallen ....the screen says ...Samsung galaxy sIII GT-19300... i putted the phone before i went to sleep and it worked perfectly good.. but the next morning my phone was of and when i switched it on it didn't want to go pass thiss screen ..i tooked the bat3 out but stil just came on until the screen..how can i check if my firmware is updated via wifi .. i only use wifi"
Samsung galaxy 7 stuck in restart loop
Try to hard reset your unit.
  1. Firstly, hold down the Power key for a short while to turn off the device.
  2. In the next step press and hold together: Volume Up + Home + Power button for a couple of seconds.
  3. Release held keys when the Samsung Logo appears on the screen.
  4. After that select from Recovery Mode menu "wipe data / factory reset" using Volume buttons to navigate and Power button to confirm.
  5. Choose "Yes -- delete all user data" to confirm the whole operation.
  6. Then select option "reboot system now"
4answers
How to resolve constant boot loop in samsung galaxy fame
use usb connection from your phone and your computer to upgrade your phone's operation system from the samsung website
I have m8s tv box stuck on first page I tried the hard rest by insert toothpick on av hole nothing happen it get black tv screen
android tv box stuck on a9 cortex start up screen ? - YouTube
? 0:38
https://www.youtube.com/watch?v=M1PuUl_OjOA
Feb 6, 2014 - Uploaded by wayne nottz
android mx tv box stuck on a9 cortex boot up. ... I have the same problem gets to MBOX and stays there ...
How to factory reset the U-M8 TV box, How to restore your ...
? 4:59
https://www.youtube.com/watch?v=cHuPeWU2cTA
Dec 14, 2014 - Uploaded by EntertainmentBox
I will show you how to use the android system first and also how to reset with pin in ... ... factory reset M8 but ...
stuck on m8 box logo - FreakTab.com
1helpful
Samsung glaxy s3 turn off without reason
it means that something is cutting the power, if the logo appears and then it turns off then consider replacing your battery, if it turns off without the logo then something in internal circuit is causing the problem
My samsung S3 mobile is frees and not turn on kindly give me solution
this will wipe your phone and any glitches that may be associated with it:::sgs3 hard reset or reset Galaxy S3: PRESS AND HOLD VOLUME UP + Home Button + Power
Turn the phone off
Press and hold Volume UP and Home (center) button
Press Power until the phone vibrates
Wait until you see the Android logo then release all the buttons
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES...delete all user data with VOLUME DOWN and then Press Power
After format, press Power again to reboot the phone (select reboot system now)
2answers
How do I fix this when the only thing showing up is a green android symbol on the reset screen and nothing else. I don't even get the option to reset on this screen.
Have you tried re-flashing it?
Was you trying to put a custom rom on it?
Have you tried to return it to stock?
Try these sites. Stuck in green android logo
This site helped me a lot. You may have to dig a bit for what you want but i am sure its there.
Android Area51
Rember to use key words like galaxy xx, green android logo, stuck on xx screen
Mm#6 error on samsung galaxy s3
Does it come up at all? Have you tried to factory reset it?
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
