Question about Crate Music
I need to know how to fix the third switch on a crate GLX 120 guitar amplifier footswitch if you can come up with a schematic blueprint or even picture be much appreciated
Posted by Ricky riffmaster on
Need the cables for crate flex ave footswitch
The easiest way would be to contact Crate customer service, or Guitar Center, or Musician's Friend, or Ebay.Here are the links-
http://www.crateamps.com/support/index.php
Guitar Center Music Instruments Accessories and Equipment
Musician Friend Musical Instruments Store
eBayeBay
Jul 02, 2016 | Crate Music
Need the cables for crate flex wave footswitch
They look to be 1/4" stereo male to male jacks (known also as TRS). I don't know where you are but they are easily available.
You need a pair of them at the length you need.
e.g. SHORT 1m 6 35mm Stereo TRS Jack Plug to Guitar 1 4 Jack Male Musical...
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Got a Crate VTX 15 guitar amp, and wondering if I can use a footswitch with it?
sure, why not, the footswitch connects between the guitar and the amp, with your guitar into the footswitch, go rock that thing!
Mar 10, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Sep 16, 2011 | Crate Cfs3
Wiring a crate 2 button footswitch to work with the prometheam ibenez bass amp...can it be done?
Mixing brands on footswitches, even within the same brand but different series is NEVER a good idea. While many can be converted by elecvtronics competent techs, the effort is usually not worth it for anything other than the simplest footswitch.
Aug 26, 2011 | Ibanez P500H Promethean Bass Amplifier...
My clean channel wont turn on. Light just stays red on distortion.
Insufficent information !!! Are you controlling this by the footswitch or the onboard switch? If the onboard switch and you HAVE at some point used the footswitch, likely the contact on the footswitch jack has failed that transfers control to the internal switch. If you haven't tried the footswitch see if that has control. I can send you the link to the schematics if you know how to read them. Here they are:
http://elektrotanya.com/marshall_mg250dfx.pdf/download.html
Scroll down to the little link that says "Get Manual" and click on it to download.
Apr 15, 2011 | Marshall Amplification Marshall MG250DFX...
ON my fender mustang II as I switch channels with my footswitch there' s a lag before the sound comes up
Possibly you are holding the switch down???... it MAY activate on the release of the switch. Try quick tap on switch.
I tried to find schematic to analyze this but could not find one.
Apr 06, 2011 | Fender Mustang II Guitar Combo Amplifier...
Fender Hot Rod Deluxe Footswitch
Main thing to verify is that the particular footswitch and cable you have is specifically for that amp. If it is not the right one, that is your problem as there is very little compatibility among footswitches.
Looking at the schematic, plugging in JUST the cable shifts operation as you observed. This uses a crazy circuit in which AC is applied on the cable and the footswitch has a diode each direction that causes the amp to shift between the states. when you plug a bare cable in, it disconnects the internal diodes and switches for control at the amp, hence the signals float.
You should investigate the footswitch to make sure it is the right type with the diodes resistors and caps that is for the Fender Deluxe.
You can find the schematic for the amp here:
http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_Deluxe_Schematic.pdf
Look at the circuitry of the switches on the schematic at C8. Your pedal should have similar circuitry. Assuming your cable is good, the problem would be in the pedal itself.
Jan 01, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
85 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
