Question about Golf
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart. This is a electric golf cart
Posted by Jerry Lirette on
Bill Boyd
    Top Expert:
  • 53,816 Answers
Check for a broken return spring for the preal
Posted on Mar 18, 2017
Testimonial: "The return spring is not broken"
  • Jerry Lirette
    Jerry Lirette Mar 19, 2017
Why won't my electric golf cart go when I press accelerator?
I would think either the batteries are dead, or its broken.
Sep 11, 2018 | Cars & Trucks
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
1986 ez electric 4 seater golf cart serial # 438359
re wire the golf cart. poor ground and possible battery replacement needed
Sep 15, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Golf cart will not start when gas pedal pushed. Will start if cross solenoid. Any ideas.
check the wires from the accelerator pedal to the solenoid (fuse)
replace the solenoid
Aug 12, 2015 | Golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Jan 05, 2009 | 1995 Volkswagen Golf
Golf Logo
648 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
