Question about Black & Decker Food Processors
My B&D older food processor won't start. Easy fix?
D15P1D
Posted by Patti on
2 Related Answers
Anonymous
SOURCE: assembly directions for food processor
I had same problem and found answer on another website:
Front on machine is the one with the label on it.
One thing: the instructions aren't particularly clear on assembly. The bowl handle should be *toward* you when you lock it on the base, pointing toward you when you stand facing the label side with motor to right and bowl to your left. Then the lid just slides right on and when you turn counterclockwise a quarter of a turn it locks into place with no effort as the key slides into the slot and locks. I had this idea the handle should be on the backside of the machine, and it will fit on that way, but then you can't get the lid to fit securely.
Posted on May 26, 2009
John McPherson
  • 1212 Answers
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Posted on Dec 20, 2011
Testimonial: "really helpful thanks"
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
Do you have an operations manual for the black and deck quick and easy food processor
The Use and Care Guide for your Black & Decker FP1300 Quick N Easy 8 Cups Food Processor can be found online here:
http://useandcaremanuals.com/pdf/FP1300-1400Series791.pdf
Thank you for using FixYa!
Sep 24, 2011 | Black & Decker FP1300 Quick N Easy Food...
My blade broke on my Food processor Model CFP10
Available replacement parts for your Black & Decker FP1400 Quick N Easy Plus 8 Cups Food Processor can be found here:
http://www.directpartsandproducts.com/food-processors-fp1400-c-1_378_406.html
Jan 21, 2011 | Black & Decker FP1400 Quick N Easy Plus...
Replacement Bowl for Kenmore Food Processor Model #69703
check with marbeck.com. I am almost sure the cuicannart parts they sell will fit this model under model DLC_7
Sep 09, 2009 | Kenmore KFP-70 Food Processor
Food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
243 people viewed this question
Top Black & Decker Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
