Question about Westclox Audio Players & Recorders
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off. Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
SOURCE: Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
SOURCE: Model westclox belleville quartzmatic
Your best bet would be to send it to the Clock Man in Fullerton, California and have him repair it for you. Here is a link to his website at the bottom of this post. My family has used his services for years & years without a problem.
http://www.theclockmanonline.com/
Call him and explain the problem you are having. If anyone can repair it, he can.
Posted on Jul 28, 2011
SOURCE: Westclox model 22717
Wesclox 22717 reset problem
Searched the web but couldn't find the answer either. I was about to throw the clock away when my 10 year old son came by and said "press hard". So that's the answer! I used a pen to press the time button then hit the hour and minute and it did the reset. Good luck.
Posted on Sep 23, 2011
