Per the manual you can upload 1 at a time and use it. To do this, you need to remove the navigation MicroSD card and insert your own with a .bmp image.
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input.
A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables).
A line-out converter should be available any place that sells car audio accessories.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short.
BMW
