Question about Hyundai Televison & Video
My husband has accidentally turn our hyundai tv's keylock. now all the bottons are not functioning including the power botton. how are we going to unlock it without the original remote?
Hyundai tv keylock
Posted by nova jove on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: remote code
hi
google the tv make hp4240
cost £12 for remote
just like the real thing
martin
Posted on Mar 15, 2008
Anonymous
  • 35 Answers
SOURCE: my tv wont turn on even the standby botton isnt on
Hi
You have power supply problem.Please go to ebay and buy cheaper
price:
AKAI LCT3201TD POWER SUUPLY MLT169A REFURBISHED CHAINA
Thanks
GEORGE
Posted on Mar 17, 2009
Anonymous
SOURCE: Need help programing a RCA NITEglo remote cantrol
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player:
http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
Posted on May 05, 2009
SOURCE: I have a Sony trinitron tv that will not turn on.
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
Arunas
  • 18 Answers
SOURCE: My TV does not respond
Can try search new remote on : www.remotes.lt
Posted on Apr 08, 2011
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
My lcd tv keep flashing the on botton when i turn it on and there is no image,i have to keep pushing the on botton until the on botton light stay on and the screen comes on,
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
Nov 25, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
Cannot program Insignia IS-TV040919 20" TV on a comcast 3 device remote (red OK button) None of the codes work.(10171,11204,11963,12002)
No problem, This issued will be only resolve with regular TV's, not LCD or PLASMA Tv's. Just press TV botton locate on the top leftside of the remote, right after hold the SETUP button for 3 seconds once the TV botton blink twice go and press 991 then 1 again, right after you have pressed 991 the TV botton will blink twice and when you press 1 will blink twice as well, after those steps keep pressing the channel up botton until your Tv shut off. That will work. Good luck
Jan 07, 2010 | Insignia Televison & Video
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
My tv wont turn on even the standby botton isnt on
Hi
price:
Thanks
GEORGE
Mar 03, 2009 | Akai LCT3201TD 32 in. LCD Television
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Bad power botton,volume,channel,and menu botton
The buttons in front panel of the tv are bad,part number for these are 268854
Dec 16, 2007 | RCA P52937 52" Rear Projection Television
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Hyundai Televison & Video Experts
Marvin
Marvin
WORLD MODERATOR
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
