Question about Schlage Locks & Locksmithing
My ZWave Schlage Smart Lock shows "Lock Was Changed" in the Activity screen. What does that mean?
Posted by Tracy Adamski on
The door will not lock. Inside handle acts freely when lock is engaged. I have changed battery with no luck. Any suggestions?
The inside handle will always open the door whether it's locked or not. This is a safety feature. If it locks from the outside then it's working as designed. Might help you to watch this video.
http://consumer.schlage.com/service-support/pages/instructionsandmanuals.aspx
Feb 28, 2016 | Schlage FE595VCAM716ACC Camelot Keypad...
Schlage keyless door lock wont lock
Can you provide more details? I've had similar problems with Schlage Sense and August Smart Lock. So I might be able to help you.
The first thing we should try is reseting the lock and try setting it up as brand new one.
Mar 21, 2013 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
The switch that unlocks my schlage FE595 door lock from the inside needs changed and I can't find a replacement.
Schlage's warranty policy covers the electronics for 1 year to the original purchaser. Last week I answered another question about buying the keypad assembly for a Schlage lock. Here's his experience:
"I had commented on their site about no spare parts being available and one of their reps contacted me and says they are going to replace the lock for me. This is a very generous gesture on their part and if it comes thru, will be a great deal for me. However, the problem still remains that there are no parts available for the other people that have this same problem. The locks have a lifetime warranty on the finish and mechanism but the electronics only have a 1 year guarantee...."
I suggest that you contact Schlage, but you will probably find that you can't buy the switch you need. Plead your case, ask to have it elevated, make a negative comment on their website like the other gent did.
Here's the contact information:
Go to Schlage.com Click on :"For your Home", then "Service & Support", and under that "Contact Us"
Feb 26, 2012 | Schlage FE595-CAM-ACC FE595CAM620ACC...
My schlage keypad lock has worked fine for a year. Yesterday, I entered the code and the handle would move but nothing would engage to open the door. It was if I was using the wrong entry code. I...
This is the first place I urge you to look for information on your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
On this page you will find links to installation instructions and videos for the various models of Schlage locksets.
I f you are not able to resolve your problem from there, then I recommend that you contact their Customer Service (under the Service and Support link) also found on that page.
There's always a good chance that you can press them to cover repair parts or replacement of your lock, even if it is out of warranty.
May 13, 2011 | Schlage Locks & Locksmithing
Schlage Cobra lock. The lock will not lock
Please re-post your question with more specific information about the problem.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Mar 18, 2011 | Schlage COBRA by Keyless Lock
.how to reset code push
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There's a video that shows you how.
Nov 20, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 20, 2009 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Logitech harmony remote 1000 not operating CBus lighting
Is there an IR receiver (or if using the RF extender, IR eyeballs connected to device and the RF extender) that you are pointing at to control the CBus lighting? If not, there is no way to control it. The Harmony 1000 will only communicate with the RF extender through Zwave, so you can't communicate with other Zwave devices, like you can with the Harmony 890 for instance.
Hope this helps,
81
Dec 08, 2008 | Logitech Harmony 1000 LCD Touchscreen...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Locks & Locksmithing Logo
438 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
