Sewing Machines Logo
d
diane farnsworth Posted on Mar 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a longer embroidery arm unit fit my Viking designer se so a majestic hoop works
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Mar 13, 2018
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613585
Points
59176
You should probably check with your Viking dealer. You'll want to get the right equipment for your machine.
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Oct 15, 2009
SOURCE: I'm using the Mega Single Hoop for the Viking
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Anonymous
  • 201 Answers
  • Posted on Feb 01, 2010
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Anonymous
  • 201 Answers
  • Posted on Jul 17, 2010
SOURCE: I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Testimonial: "Thanks so much for your feedback on the Quilter's Hoop problem. I did as you suggested putting the Large Hoop 240x150 in the preferences and darn if it didn't work. I have since learned that my technician wants $50.00 for a part he says Husqvarna says my machine needs because it was built before the Quilter's Hoop came on the market. What do you think of that? Thanks again for the solution."
Anonymous
  • Posted on May 04, 2012
SOURCE: Viking designer se screen is stuck in welcome
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on May 17, 2012
SOURCE: my viking #1+ embroidery unit when i turn it on the arm won't move to line up to embroidery
it would be a good idea to have the machine checked
Husqvarna Designer Ruby 90
Here is a video about calibrating the Ruby 76. Yes, I know it is not the 90. Husqvarna Viking Designer Diamond 76 Calibrating the Embroidery Hoop - YouTube Well, the only thing you learned there is calibration was supposed to be automatic. Moving right along...
Make sure the embroidery module is seated, i. e. attached to the machine properly. Check that the fabric is tightly hooped and that the inner hoop matches the outer hoop.
There are plastic gears driving the unit that may break yielding a grinding sound. Fine wires in the unit may also break, rendering in inoperative. Such repairs call for a serviceman. No seeing the machine, it is difficult to know what the exact problem is.
I suppose you have used the user's guide built into the machine. It offers detailed instructions on calibration. My Sewnet offers a support link near the bottom of its page. The dealer locator is supplied for your convenience. My apologies for not being of more assistance. I am uncertain of the problem.
The User's Guide on the Husqvarna Viking Designer Ruby 90 - YouTube
Dealer Locator ' mySewnet
1helpful
Does the Husqvarna Designer SE use the Designer 1 embroidery arm?
The embroidery arms are usually machine specific. I had to label two Husqvarna embroidery units for my neighbor. She had mixed up which embroidery unit went with which machine. She was about to take the machines to the repair shop after the units failed to properly connect to the the embroidery socket on the machine she tried to use. Once the correct embroidery arm was connected to the matching machine, the unit worked fine. (One of the machines was a Designer 1. I'm not sure about the second.)
The largest hoop available for the Designer SE is 360 x 350 mm. The compatible hoops are listed here: https://www.husqvarnaviking.com/en-US/Accessories#.947 .
I hope this helps.
2answers
Can the embroidery arm of a Designer 1 Viking sewing machine be repaired?
It depends what needs repairing? They are available to buy
viking embroidery arm ' eBay
https://www.ebay.ca > sch
21 items - Husqvarna Viking Embroidery Unit/Arm Attachment Model VSMAB ForDesigner 1 Sweden · Husqvarna Viking Designer 1 Embroidery Arm, W/ Hard And ...
husqvarna embroidery unit ' eBay
20 items - Husqvarna embroidery unit for #1+. Embroidery unit in case,. Brand New. C $400.00. Buy It Now. Husqvarna Viking Designer SE Embroidery Arm Unit ...
Or ask Husqvarna Viking to repair or replace under warranty
Machines - HUSQVARNA VIKING®
https://www.husqvarnaviking.com > Machines
The EPIC™ ' 980Q sewing machine is our most advanced and comprehensive computerized sewing machine ever. Made for Sewers, by Sewers™ to set your ... ‎Sewing · ‎Quilting · ‎Designer epic™ 2 · ‎Designer sapphire™ 85
I have a Viking designer ruby machine. I am trying to embroider a name. I have the right hoop and the design fits the hoop and I keep getting an error message.
Sometimes machines will not work because even though the hoop appears large enough, there is not enough leeway for the presser foot to maneuver inside the hoop. This is a common issue with embroidery machines. The probably answer is to either shrink the design or use a larger hoop.
Embroidery Arm is not moving right/left
Check to notice if when the embroidery arm is installed and you turn the power on does the embroidery unit move as it calibrates the stepper motors. If not I would first check the plug where the machine and embroidery unit attach. If this looks ok and is not out of place it could be a cable, or the main circuit board. Both of those are for your dealer to repair.
2answers
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
8helpful
2answers
7helpful
Trouble with Viking 955E Embroidery Unit and Control Panel
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials:
http://www.husqvarnaviking.com/us/6616_393.htm
Some general hints and tips:
  • Always turn your machine off when you attach or remove your embroidery arm or when you  insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
The Viking site also has projects for the 955E that will help you learn to use some of the features - you can probably sew most or all of the free projects on the site, but projects for the 955E incorporate features on your machine that might be available on others. And look for the free designs!
Hope this helps get you started.  If you and other readers have a minute to rate this information (good or bad, or indifferent), your rating will help me determine if I understood your question and if my answer is helpful.
A few more recommendations...You can order a manual for your machine from any Viking dealer and probably online, and I recommend that you do. Your machine has some very cool sewing and embroidery features. I sold Vikings, so I can answer specific questions about many individual features, but Viking manuals are not expensive and can help you save time and avoid irritating problems.
If you have more questions, please comment and I will do my best to help you further. I am pleased to answer general questions about embroidery, if you want hints and tips or run into problems.
Cheers, Ginny
2answers
Embroidery Arm
Here's the number for Viking - they're really helpful over the phone. They can probably walk you through it.
VSM Sewing Inc.
31000 Viking Parkway
Westlake, OH 44145
440-808-6550
800-358-0001
[email protected]
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
