The speakers work but no headphones
SOURCE: Toshiba Satellite Pro A200 - Vista - Sound problems
You should check if in the device manager the sound card shows up. Also, check the BIOS to see if it is not disabled.
SOURCE: Crackling noise from subwoofer!
If ayou have a system with speakers that works and a different set is crackling
the set that crackles is to be determined the bad set. Cones dry up a bad assembley just coinsidents having a bad set of speakers. It is an AUDIO problem not a computer problem
SOURCE: my speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
SOURCE: built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
SOURCE: Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
