Hardware & Accessories Logo
How do i change the time in oxo triple timer - Hardware & Accessories
The numbers on my OXO triple timer screen are faded. the batteries are fresh. If I hold the timer to the light a certain way I can see the numbers. The timer and clock works otherwise.
The Reviews are good. I would try with another set of batteries. If that doesn't work, return it to Oxo under their Better Guarantee
At OXO, we believe in better - better design, better functionality, better experience - and that's exactly how we make our products. For more than two decades, we've made tools that delight and exceed expectations. Our curiosity drives us. Your satisfaction inspires us. And we hope our attention to detail is why you'll reach for our products again and again. If you're not satisfied with your purchase, we want to hear about it. We'll replace it or refund you, because we're here to make it better - guaranteed.
*This guarantee is only applicable to defects in material or workmanship under normal household use and when cared for according to the Use & Care guidelines we provide. The OXO Better Guarantee does not apply to OXO Brew appliances, select OXO Tot items, bakeware, cookware and knives. Please see your individual OXO product packaging or instruction manual for more details on the applicable OXO warranty terms.
In the link down below 'Don't Waste Your Money' is the name of the site, not a reflection on the product!
OXO Good Grips Triple Timer - Don't Waste Your Money
www.dontwasteyourmoney.com > products > oxo-good...
A detailed review of the OXO Good Grips Triple Timer along with our in Kitchen Timers Buying Guide. ... We love the large display and unique alarm for each timer. ... from certain heights and distances, otherwise the numbers fade from view.
Triple Timer - OXO
www.oxo.com > triple-timer-630
The Triple Timer features an intuitive interface and easy-to-read LCD display. All three timers are 100 hours in duration. Angled face adds visibility on ... Missing: faded ‎' Must include: faded
INSTRUCTIONS FOR USE - OXO
www.oxo.com > PDF_Files > 556_gg_1071501_booklet
PDF Instructions for Triple Timer use: 1. Place batteries securely inside battery compartment and close battery door. Display will show 12:00:00. 2. To set clock, press ... Missing: faded ‎' Must include: faded
1helpful
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
How to change the hour on the OXO triple grip timer.
The instruction booklet for OXO's Triple Timer Model ## 1071501 can be downloaded here:
http://www.oxo.com/download/556_gg_1071501_booklet.pdf
How do I change the clock on a oxo digital timer?
I'm assuming that you're referring to OXO's Digital Timer Model #1061978. OXO doesn't provide a copy of the instruction booklet for download, but I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
What battery does an OXO small kitchen timer need?
I'm assuming you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
1helpful
2answers
Reset cloock on oxo 3 timer
The instruction booklet for your timer is available for download here:
1helpful
2answers
How to set oxo digital magnetic timer
For OXO instructions, you might try contacting the company:
Copy following link:
http://www.oxo.com/contactUs.aspx
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How do I set the clock on my oxo triple timer?
The instruction booklet for your OXO Triple Timer Model # 1071501 is available for download here:
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
