Question about Adidas Watches
I have an adidas adp3190 performance watch. the face says "turn bezel" and has a picture of an arrow in the shape of a circle going counter clockwise. When i turn the bezel it goes black then says R2
I have an adidas adp3190 performance watch. I just went top it on and when i looked at the face it says "turn bezel" and has a picture of an arrow in the shape of a circle going counter clockwise. So i turn the bezel like it says and after about 3 turns it beeps and lights up everything on the face then goes black. Then it says "R2" and the cycle repeats. What does this mean and how do i fix it?
  • G hill
    G hill Jul 29, 2018
    Did anyone come with an actual answer/ solution
Dave Guimod
    New Friend:
Hi, I also have that problem like yours. Is your watch already fixed? Can you please share. Thanks.
Posted on Jun 14, 2017
  • Nur Fatihah
    Nur Fatihah Oct 24, 2017
    I have problem like yours also..can you share how you fixed it?
5 Related Answers
Baabaabing
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Posted on Mar 15, 2008
Anonymous
SOURCE: ADIDAS ADP 1059
Push the button just above the crown on the right hand side.   (this is for a adp1055 but I would think it would be the same on similar models
Posted on Oct 08, 2008
Anonymous
SOURCE: Sportcraft Heart Rate Monitor Watch
On mine you press and hold the ST/FWD button.
Posted on Feb 17, 2009
Anonymous
SOURCE: How do you switch off the sound
For my casio calculator watch (mod no. 437438), I go into the calculator mode and press the button below the one that pops out at the side (don't know the correct term for it sorry). Pressing that button will mute the sounds of your watch, if you want to retrieve the sound, do the same thing again.
Posted on May 17, 2009
David Tolond
  • 2501 Answers
SOURCE: How do I set my Fossil watch? It has three dials
Fossil do not have a list of instructions under model numbers but issue a list of generic instructions which you have to wade through to find the one that suits your watch.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and put your cursor over each of the ones listed in the Multifunction section until you reach the one that looks nearest yours and download the file.
Posted on Jan 16, 2011
My outer ring will not turn on my new watch
it can only be turn counter clockwise, if it doesn't move, bring it to watch service center. i hope i had been helped you.
Aug 20, 2011 | Timex Expedition T46601 Watch
My watch beeps every hour & alarms every 3 hours. How do I remove this?
Adidas do not list their watch instructions by model but give a complete list of all the various models they make, including a picture of the watch face.
If you go to http://www.adidas.com/campaigns/watches_fw07/content/index.asp?strCountry_adidascom=us you can click on the language and arrive at a list which you can scroll down until you find the instructions that apply to you watch.
(I suspect that you press the mode button (8 O'clock) to arrive at alarm (AL?) and the press the one at 4 O'clockto disable it but to be sure you need to find the correct instructions) Good luck!
Feb 16, 2011 | Adidas Candy Digital watch
Luminox bezel
Grab the knurled edge of the bezel and turn counter clockwise. It only moves in one direction- to the left, counter clockwise.
Mar 14, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
What are the dials? How do you set knobs? Can't move center knob.
The 3 dials are the chronograph for timing an event such as motor racing(a stop watch). The centre know (the crown) has to be unscrewned counter clockwise and then pulled out from the case at, first stage will allow changes to date, second to set the time.
The outside bezel is used as a means of measuring time, eg. 20min, from a random starting point and is often used for 'oxygen' time for diving.
Feb 12, 2009 | Rolex Daytona 116528 Wrist Watch
Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Mar 15, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
1,759 people viewed this question
Top Adidas Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you an Adidas Watch Expert? Answer questions, earn points and help others
