Question about Panasonic KX-T7731 Corded Phone
HOW TO RESET PANASONIC KX-T7731 - Panasonic KX-T7731 Corded Phone
Posted by Rehana Patel on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Posted on Sep 16, 2007
Anonymous
  • 4 Answers
SOURCE: Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Posted on Apr 09, 2008
Anonymous
  • 113 Answers
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Posted on Mar 18, 2010
cnavarro
Carl Navarro
  • 2460 Answers
With the phone idle, you keep pressint the * (or the TRANSFER key) until what you want is on the display. It uses one or the other key because the 77xx phone works on more than one system.
Carl
Posted on May 11, 2010
Anonymous
SOURCE: how set time for panasonic kx-t7731? thanks
This worked on mine:
Press Program, then 0
Make note of the numbers on the display (should read something like 100514 5 12:30PM).
Enter two digits for each in this order year month day.
Enter the same number that appeared on your display between the date and the time.
Enter the time.
Enter 0 for AM, 1 for PM
Press Store (phone should beep twice)
Press Program
Posted on May 14, 2010
Changing the voicemail message on Panasonic KX-T7731
The KX-T7731 isn't an answering machine.
If the voicemail is on an answering machine connected to your phone line, consult its manual/
If the voicemail is on the phone company's server, look up the instructions in the phone book, or conrtact the company.
Oct 27, 2016 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
How do i change the voicemail message on a panasonic kx-t7731
How do I reset from the attendant station or access 999
Nov 24, 2010 | Panasonic KX-T7731 Corded Phone
Massage password reset I forgot the password. How can I reset the password of KX-T7731?
It can be reset from the System Administrator's mailbox (999). If you don't have that password, then you need to get it from the installer or someone who has it. That mailbox can go into the system and reset all user passwords to either a default, or empty.
Carl
May 06, 2010 | Panasonic KX-T7731 Corded Phone
DIsplaying date and time on KX-T7731 phone
While the handset is still on the cradle/hook press * or # until the desired view is diplayed.
If this was helpful please rate / vote
Thank you
Jul 21, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
1,413 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
