Question about Summit Refrigerators
I have a summit freezer SCFF235 the evaporator fans do not come on
Posted by Diego Romero -... on
1 Related Answer
Anonymous
  • 47 Answers
SOURCE: Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Posted on Nov 11, 2009
Testimonial: "Thank you for the response Fridgie!"
Ice buildup summit freezer
Check if fan is working by pressin the door switch, or if you have exceptional high load recently. Remove everything off the unit overnight before you turn it back on again..
Oct 11, 2014 | Summit Refrigeration FFBF245SS - Counter...
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
What is the evaporator
The evaporator is the part of the fridge that gets cold, more correctly it removes heat. It is usually located in the freezer and a fan motor, evaporator fan, move air thru the evaporator to cool both the fridge and the freezer. Some units have two evaporators, one for the fridge and one for the freezer.
Mar 12, 2013 | Refrigerators
Is the evaporator fan suspose to be pulling air from inside the freezer over the evaporator or pushing air from the evaporator?
The evaporator fan should be pulling air from the freezer over the evaporator and directing the air down into the frig and circulating through out the freezer.
Hope this helps.
Jan 05, 2010 | Continental Freezer Reach-In FreezersClick...
Nov 10, 2009 | Amana Freezers
Unusual noise and ice all over the freezer
This sounds like the fan is hitting the ice. If it's iced up, remove the food from the freezer and place in refrigerator.
Take the bottom panel out of the inside of the freezer section and then remove the back panel from inside the freezer section. You will then be able to see the evaporator fan. You will need to check to see if the evaporator fan will turn with the power of the refrigerator turned on.
You also want to look to see if the evaporator fan is turning and hitting ice which means the evaporator is froze up. You will need to check and see if the evaporator fan is bad or the defrost timer is bad.
Oct 17, 2009 | Refrigerators
Freezer not freezing fridge not cold, freezer frosted up
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 03, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
Not cooling as normal 2008 summit ridge reserve dometic rm 1350 with ice maker. started acting up last year, fans not coming on so I addedan external one .problem solved until recently lost power. now...
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 21, 2009 | Refrigerators
Refrigerators Logo
205 people viewed this question
Top Summit Refrigerators Experts
ray gallant
Tom Chichester
David Spradling
David Spradling
Are you a Summit Refrigerator Expert? Answer questions, earn points and help others
