Question about Jura Capresso Impressa Coffee Makers & Espresso Machines
Jura Impressa C65 says Fill Beans when hopper is full
Beans don't feed into grinder - runs w/o sounds of grinding
Posted by Terry Weaver on
4 Related Answers
Anonymous
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
Anonymous
SOURCE: my jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
Posted on Dec 22, 2010
frankjuka
SOURCE: My Jura Ena 5 gives a 'fill beans' message
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Posted on Mar 21, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: I have a Jura Impressa E85 purchased in 2006. The
This sometimes happens when after cleaning the machine. I will explain: The beans have a natural oil on them as you know, that also helps coat the hopper for beans to fall. Sometimes when cleaning the machine, the natural oil that is built up around the hopper is not there. Once you brew a cup sometimes the light will go off on its on. If the beans by shaking the machine will not drop down, try using a wooden spoon and help get them going. Other way, is cleaning out the beans completely and then spaying some PAM (used for cooking). What I also did was locate the complete manual for you to download and read page 21 in the trouble shooting area. Here is the link you can copy and paste and put in your browser.
http://www.uk.jura.com/home_uk_x/service_support/download_manual_jura_impressa_e80_e85_english.pdf
I hope this helps you, and please rate my free advice accordingly , thanks Mike
Posted on Oct 14, 2011
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Cleaning burrs of oily residue
Hi
There are many ways to clean oily residue from your burrs. You can order a grinder cleaning tablet from online stores called Grinds by Urnex. Some people use white rice but if you don't get it all out you will have rice in your coffee. You can take them apart and clean them manually but if you don't reassemble it correctly you will not get a good grind. I think the easiest way is to get some cheap light roasted beans ( doesn't matter if they are old ) but never use shiny beans because shiny beans have lots of oil.
Set the grinder to a very coarse setting, on a Rocky 7 higher that you currently use. You can turn it to a larger # any time but it has to be grinding to turn it to a lower #. Pour a cup of cleaner (beans, or rice) into the bean hopper and turn the grinder on. Grind the whole hopper through the machine. If you use grinds just a couple of #'s higher is all you need. Once you have cleaned the burrs you will need to grind some of you beans to purg the cleaning debris for the burrs and chamber. When you see no more cleaning compound you can turn the hopper back to where it was leaving the motor run. Once you get it back test with your beans.
May 12, 2011 | Rancilio (RAROCKYND) Grinder
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
427 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
