Televison & Video Logo
Carol Wells Posted on Mar 12, 2017
What is the best way to connect my Bravia to the internet. It has a Network page but not a WiFi page. Is there a generic WiFi extender I can use? KDL40XBR6
gymnation 247
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 12, 2017
gymnation 247
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
270
Points
15
Connect a internet cable to your Tv and to the LAN of your router
2answers
TP-Link WiFi Range Extender. How do I enter a new WiFi address on my TP-Link extender?
Please check the side or bottom of the extender for the steps to update it's wifi signal. If not there, then please visit the extenders ip address through a computer connected to your home internet network, there might be a control page for the extender there. Otherwise, please use the table contents in your wifi extender's manual.
Thank you.
How to setup wifiextender benefits of wifi range extender
<h1>Benefit</h1>
A WiFiextender increases the range a wireless signal travels from a router through a wired connection. Because WiFiextenders are wired, they provide stable, strong connection points to your network.
<h1>How To Setup Wifi Extender</h1>
Without WPS it may take a little longer to connect your wifi extender, but the idea is the same. First, you'll want to connect the end of your Ethernet cable, or Cat5 cable, into the Internet port on the extender and the other end into the Internet port on your wifi router.
If you've had the same internet setup for awhile and you didn't set it up yourself, don't panic. You can setup a wifi extender on your own. Can't remember what the Ethernet cable is? It's typically the blue cord.
The next step is to connect the Ethernet cable into the LAN port on the extender and the other end into an Ethernet port on any computer that has a connection to your network. After you launch your web browser, type the IP address of the wifi extender into the address field (or address bar). This is when it's handy to hang onto the instructions as you will find the address in the manual.
After you have entered the extender's IP address, the configuration page will open, and you should click wireless settings, enter your wireless network name in the SSID box, and then save. Next, click on wireless security, select the security type (like WEP), type in the password, and then save. Keep in mind that your options may be different depending on your operating system, but if done correctly, you will have successfully setup your wifi extender.
After you unplug your Ethernet cords from the extender and router, you should plan on positioning your extender within an acceptable range from your router.
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
2answers
I cant setup my belkin wifi extender
Kindly match the wifi settings of the router to extender and give a static ip to extender in range to router lan ip
2answers
How to set up netgear ex6100 wifi range extender
  1. Plugin your extender in electrical outlet.
  2. Place your extender near your router when first time your are setting new extender.
  3. Launch any web browser and enter mywifiext.net. The New Extender Setup page displays.
  4. In the Password section, type the existing WiFi network password. Default user name is admin and password is password.
5. Click continue and a message box displays saying that your extender is connected to the new extender WiFi network
6.
Now, you can connect your device to the extender network, go to the WIFI settings and connect to the extender's new network.
7.
Netgear EX6100 Setup is successfully completed now place the extender at the desired location and enjoy seamless Connectivity.
2answers
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
2answers
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
I purchased a Netgear Universal Wifi Extender for my ipad, i've set it on on the ipad and it says its connected and evreything and the little correction mark comes up on the ipad showing connected. the...
Extender means it extends the existing Wifi or network. So the iPad now connects fine to the extender, but the extender needs to connect to the existing network either via Wifi or cable. You need to open from the iPad the admin page of the extender and find the connection details there to your existing network.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
