Computers & Internet Logo
P
Paul Fischer Posted on Mar 12, 2017
How to get a WD My Book 4TB with a brand new harddisk drive working again?
I mean, how to reach a factory reset state. I don't have the original drive anymore and I only get I/O errors when I try to initialize it with Windows Disk Management. There is no defect but some kind of protection etc.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 09, 2008
SOURCE: installing new HDD & another DVD drive
Problem with HDD is power usage 320gig uses to much, WD 160 is best though just a bit small which may cause issue if you fill it up. WD200gig OK but at threshold of what power supply can handle. Disk needs to be filled with original disk image to get firmware and custom file system. Smallest I've got image down to is 11gig
A
Anonymous
  • Posted on Aug 31, 2008
SOURCE: my computer will and won't reconise my WD My Book but not both drives
any answer?
Anonymous
  • 32281 Answers
  • Posted on Nov 29, 2008
SOURCE: Dell Dimension 2400 - Adding second HD
I presume that the hard drives are ATA drives, and if the WD and Maxtor are installed on the same IDE cable then the boot drive, the WD HD needs to have the jumper set to Master or Master with Slave drive, and the Maxtor needs the jumper set to Slave drive.
If the computer on boot up doesn't recognise the boot drive the move the jumper to the CSL setting.
If the Maxtor is on the second IDE cable it does not matter if the jumper to either Master or Slave provided you do not have anything else connected to this cable. If you have a CD or DVD connected to the second IDE cable as well as the Maxtor HD then you need to check the devices on this cable (ie. the jumpers) are not set the same on both devices.
On boot up go into the BIOS and check that the master and slave devices are set to Auto (detect).
You should after booting up now see both hard drives and any CD/DVD.
The data on the Maxtor drive would include your original Windows and programs and data, you would need to remove these redundant files and programs to recover disk space.
If you can see on boot up all the hard drives and CD/DVD (as master and slave drives) but if you do not see the Maxtor drive from My Computer, then you need to delete the partition on the Maxtor drive, create a new partition, and format the drive, in this case you will not recover any of your original data.
To do this, you need to go to the Control Panel, Then Administrative Tools, then Computer Management then Disk Management. Right Click on Disk 1 (it should show a 80 Gb hard drive), delete the partition, then it would show this as an unallocated drive.
Right Click on this drive again and create a primary partition, follow the instructions and format the drive in NTFS file format.
Anonymous
  • 28 Answers
  • Posted on Oct 10, 2009
SOURCE: Virtual Disk service won't load in Disk Management
look, you can try to tell an supplier
the suppliers can help
or buy a new one xD
Testimonial: "Well, you got me to thinking. I tried the MS Fix it, but no dice. I then noticed a link and began a chat with an MS tech. It took amost3 hours, but"
Anonymous
  • 414 Answers
  • Posted on Nov 06, 2009
SOURCE: i cant initialize disk
this problem to an i/o device happens mostly when itz defective/faulty..
check the following:
1)is ur m/b compatible..check with a substitute/standby..
2)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
3)replace the data cable with a standby n see..
4)all the power connectors n data cables r properly sitted n connected..
5)update/flash the bios..
6)check for firmware update and or raid drivers (as applicable)..
if u r not a professional, try contacting ur system admin/vendor....
Testimonial: "i am going to replace my harddrive because its making a ticking noise thanks, chamicar"
1helpful
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Reset wd my passport
If this is western digital world edition
Download the computer software for your Western Digital My Book World Edition if you don't have it installed on your computer.
The software can be downloaded on the Western Digital website.
http://support.wdc.com/product/download.asp?groupid=118&lang=en
Install the software to your computer.
Go to the "Start" menu.
Click "All Programs," the "Western Digital" folder and then "My Book World Edition Software" to launch the software.
Switch to the "System" tab. Click either the "Restore Configuration" or "Full Restore" button on the tab, depending on your My Book World Edition drive.
Click the "Browse" button, select the factory settings default restoration point, and then "General Restore" to return the unit to factory settings, or click "Full Restore" and then "Restore Factory Default," again depending on your specific My Book World Edition device.
The unit powers off, all data is erased from the hard drive and the My Book is returned to factory settings.
Hope this helps
Hav e new WDElements 3TB USB ext Back up drive...fired it up 1st time, MAC desktop has the WD icon on desktop on it, but cannot copy any data to it. In the corner of the element window there is a pencil...
https://support.wdc.com/knowledgebase/answer.aspx?ID=15084
The link above states:
"My Passport for Mac and My Book for Mac are formatted with HFS+ and are Mac Ready
  1. To use the device on macOS and for Time Machine backups, format the drive as HSF+.
    For assistance formatting the drive for Mac usage, please see Answer ID 3865: How to partition and format a WD drive on Windows and macOS
  2. To use the device on macOS and Windows OS, format the drive as Answer ID 291: How to format a WD hard drive in exFAT or FAT32
  3. Click here to download WD Software for macOS
My WD External hard drive is no longer recognized by my Mac. It was fine when I went to bed. Showed no warning symptoms that I am aware of.
I would like to know the way the Drive is connected to MAC.
Have you connected it using USB or Firewire ?
If you have connected it using Firewire, Try connecting it using USB 2.0 Cable.
Let me know.
Regards,
Ron
3answers
My Western Digital 500GB EDD has been making Clicking noise
Here are some options to try: - Purchase an alternate enclosure for your hard disk enclosure in case the circuit board in the WD case has gone bad. - Try accessing the drive via MS DOS window and use CHKDSK command to repair the drive (if you can get it to be recognized). - Try connecting the drive to an alternate PC or even a Mac to see if the drive can be recognized (perform disk repair if recognized).
1helpful
My computer doesn't recognize the WD book
Several things can be done. You can try DIY software, assuming you have enough free space on your computer and it's a minor failure this may work.
Second, the enclosure itself may be failing, you can try moving the drive into a new enclosure, to do this take the drive to a PC shop and ask the technicians to test the hard drive in a new enclosure. If the drive works in the new enclosure you're set, if not move on to the next step.
Finally if you don't want the risks of the DIY method and the new enclosure fails, reply back with your location(Country, State and City) and I will be happy to refer you to a pro near you who can assist you with the process of recovering your files.
Hope this helps FixYa,
Chris
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
No drivers found
If the lights are lit and you can hear the drive spin up power is likely fine, you state you tested the USB cable so we'll assume that's fine. This leaves two large possibilities left, first the drive circuitry may have failed. If this is the case you should still see the USB Mass Storage Controller in your Device Manager. This will mean you need professonial assistance recovering you files.
If the USB Mass Storage doesn't show up in device manager you may be in luck and it may be the USB circuitry that has failed. If this is the case, pop into any reputable PC shop and have the techs move the harddrive into a new enclosure to test it. If it works there, buy the new enclosure and you're on your way. If it doesn't again you will likely need a recovery pro.
If you need a recovery pro, reply back here by adding a comment including your Country, State and City and I will refer a nearby Pro who can assist you further.
Chris
2answers
XP doesn't recognize my external 500 GB WD My book essential edition hard drive
Dear karroll.
Im having same as you're problem. but there is solution that might help you, but didnt work for me for some reason..
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
Best regards
-evo
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
