Question about Jura Capresso Coffee Makers & Espresso Machines
I need a replacement water heating element for my capresso CoffeTeam GS, can't find any. I removed the one from my unit, no manufacturer or product id tags on it, only mentions 120v 900W ...
Posted by Michel Lavallee on
  • Richard Entrekin Oct 15, 2019
    DeLonghi EH1257 works, almost an exact replacement. Will require soldering of leads. Look on Amazon. Richard
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: I cant find which typ of mainboard do I have to preform an update
There is a little program called CPUz.
Download it here:  http://www.cpuid.com/download/cpuz_149.zip
Extract the exe and ini files and run the exe.
When the program comes up, click the Mainboard tab and your manufacturer and model are right there.
Posted on Dec 17, 2008
Anonymous
SOURCE: sound card drivers on bord
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => www.ecsusa.com. or call them at 510-226-7333. Suc6 Theo.nl
Posted on Mar 24, 2009
gary1121
gary miller
  • 332 Answers
SOURCE: How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
Posted on May 30, 2009
Anonymous
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
Anonymous
  • 434 Answers
SOURCE: AMIBIOS ROM Size: 1024 KB
I am guessing that you want a BIOS update for your EliteGroup GF7050VT-M5 Ver 1.0 motherboard, am I right? There is one update, newer than yours: (read the warning about updating [flashing] your BIOS)
If you wanted something else, it is probably there too!
Posted on Jan 02, 2010
Repair Capresso CoffeeTEAM GS No heat Wont Pump Water
Check the elements. Unit heats water and forces that heated water out.
May 25, 2014 | Capresso CoffeeTEAM GS 10- cup Brewer and...
Why does my coffee maker Capresso Team GS leak water?
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (See the photo below with the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps. acccadfd-0d5d-4c31-b1b9-a56192db9bc2.jpg
May 09, 2014 | Jura Capresso CoffeeTEAM GS 46405
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
My in sink erator does not produce hot water, do you think it is the element gone bad and if so where can i get replacement? Thank you, E Harding
http://www.insinkerator.com/product/product.php?id=41&template=hwd
This is In Sinkeraters link for your product.
http://www.insinkerator.com/pdf/POU_ICU.pdf
This is the manual. It gives you al the specifications, ie, 1500 watt, temp range and so on, where you may be able to go to someplace like Home Depot and get the replacement element. I just don't know if you can get it in copper but, there is an 800 number listed in the manual where maybe they can point you in the right direction. First and foremost, I would make sure you have power to the unit. It should probably have it's own circuit btu, who knows. Check your breaker panel and make sure all breakers are on and not tripped. If one is tripped, reset it and try your heater. If you are electrical savvy, you can check for power at the unit and, check to make sure you have power through the heating element. It's probably the most common failure in these units and it's only 110v so it's not really designed to provide for a whole household. Anyway, I would start by checking the power and so on and, if you have a loss of power through the element, replace it.
Jun 05, 2011 | Emerson InSinkErator W-152 Point-Of-Use...
I think I need a new heating element for a Capresso 452. Are these available anywhere?
Coffee Maker manufacturers rarely sell individual parts for the machine aside from filters and whatnot. I recommend replacing it.
May 11, 2011 | Jura Capresso 452.01 Coffee Maker
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
Won't perk or heat water
After checking power cord and plug end to make sure these are in good condition. The unit still does not work.
It is most likely the heating element has gone out.
Suggest replacing the unit.
Oct 04, 2009 | Jura Capresso 452.01 Coffee Maker
Capresso C1500
I have tis same trouble now no water at all I need help fast
Steve
Oct 02, 2009 | Jura Capresso C1500 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
238 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
