Question about Lincoln Welding Tools
I have a Lincoln Ranger 8. It runs great. But to shut down, the off switch won't work. Once you shut it down it won't start again.
5 Suggested Answers
Anonymous
  • 11 Answers
SOURCE: ford ranger fuel shutoff switch
i bet its the ecm relay if it starts cutting out then dies then it is the ecm relay i had one that did the same thing if its your fuel relay unplug it clean the terminals and plug it back in if it still does it buy a new one and replace if you bypass it you take a chance of burning the truck too the ground and if ya dont really care about that then find your positive wire in the plug with the key on and hook it too the one that runs your fuel pump so its hard wired
Posted on Jul 22, 2009
David Tolond
  • 2501 Answers
SOURCE: shutting down
Try replacing the air filter.
Posted on Dec 21, 2009
John P Schwantes Jr
  • 1509 Answers
SOURCE: is there a thermostat shut off switch . car runs
The amount that it gets hot is a clue but theres no shut off switch. It's possible that the car is over heating and the temp gauge does'nt have enought water over it to report the problem. once the cooling system is cleared as it's full circulating and the fan will come on when it's hot ( disconnect the temp. switch on the therostate cover on the top of the transmission, ( the stat is in the lower hose ) with it disconnected and the key on the fan should be on and connected f till it's real hot. The crank senser or distrubutor module can can too hot and shut down too
Posted on May 13, 2010
emissionwiz
Marvin
  • 85223 Answers
SOURCE: 04 lincoln ls turn it off, won't start, 30 mins later starts,runs great
The only way to know what is the cause of this is to have the electronic engine control module scanned for fault codes. It is the very 1st thing that MUST be done.
Posted on Feb 22, 2012
ray garcia
  • 122 Answers
SOURCE: 95 Lincoln Mark 8 won't shutoff.
OK CAR WILL NOT SHUT OFF VERY RARE IT WILL BE THE IGNITION CAUSE IT WOULD AFFECT OTHER PARTS OF THE CAR NOW IF YOU CHECK THE FUSE BOX AND WITH THE HANDLE OF A SCREW DRIVER LIGHT TAP ON THE RELAYS WITH KEY OFF . IF IT SHUT DOWN REPLACED THE SUSPECTED RELAY. CAN SWAP THE RELAY. FOR TESTING. KEEP THE IN ORDER. GOOD LUCK I THINK IS A RELAY REPLACED WITH A NEW ONE
Posted on Feb 13, 2013
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
I have a Lincoln Ranger 8 with an Onan Engine. When started the engine runs at an EXTREME RPM. What causes this?
Check movement of the governor arm without it running. You should be able to move it by hand. If it is stuck, it could be the idle solenoid, or possibly something else more major.
Feb 26, 2015 | Lincoln Welding Tools
Lincoln ranger 250 will not shut off
Without more info I say it is a short in the switch. If not the switch trace out the wires and look for a bare spot.
Bryan
Mar 30, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Feb 22, 2012 | 2004 Lincoln LS
I drove my lincoln mrk 8 4 blocks,shut it
Check the Inertia sensor in the trunk. Press 3 seconds to reset.
If not successful try very slight throttle pressure on footpedal. Your throttle position sensor could have gone out and a slightly different position could help.
If that does not help try entering the Security code on the keypad.
Make sure you have fire from the coils. Check with Autozone about ignition relay. May just be ignition switch.
Let us know what is was please.
Nov 01, 2009 | 1997 Lincoln Mark VIII
Auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Apr 29, 2009 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
1992 ford ranger 3.0
i was once pulling a trailer with a ranger when it suddenly lost power and the engine died. turns out the problem was with the fuel shut off inertia switch. the switch is supposed to activate in case of accident. on my model the inertia switch is located in the passenger side under the glove box. dont know where yours is located. once you find it, just push the button and see if it resets. good luck.
Sep 13, 2008 | 1992 Ford Ranger
Welding Tools Logo
633 people viewed this question
Top Lincoln Welding Tools Experts
David Soto
David Soto
ROB
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
