Where is off on button on my x540s notebook - Computers & Internet
Posted by tim kallbreier on
Sattech
  • 22 Answers
Google search shows it .
Upper right key on keyboard no?
Posted on Mar 10, 2017
How to unfreeze asus notebook and keys are locked
That could be a video chip problem or display problem.
press and hold "F, J" buttons and then press the power button while holding the F J button. Now release the power button not the F J button. Release FJ buutons after you get a display.Still no display suspect the above items. Hope this helps.
Dec 10, 2012 | ASUS Eee 4G Notebook
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
My Gateway laptop model MX6453 wireless adapter is shut off and I'm unable to find how to turn it back on
Frequently Asked Questions
Q: How do I turn my notebook's wireless on and off?
A: Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide. The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from our Notebook User Guides support page. http://support.gateway.com/support/manlib/Notebooks/notebook.shtml Another source of reference for networking your computer is the Gateway Notebook Networking Guide. http://support.gateway.com/s/Mobile/Gateway/M250/8510650.pdf Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Dec 08, 2010 | Gateway MX6453 Notebook
How to activate wifi in janab
There will one of two different types of switches or buttons to enable the wireless networking feature on your notebook.
Button on the front of the notebook:
  1. Locate the wireless networking button on the front of the notebook.
  2. Press the button to either enable or dislable the wireless networking
  3. Once the wireless networking feature is enabled the button will light up amber.
Switch on the front of the notebook:
  2. Slide the switch to the right to enable or disable the wireless networking feature
    Note: The switch will reset back to the left after switched to the right. This is normal and does not indicate the the wireless feature has been disabled.
Nov 30, 2010 | Acer Aspire 4720 Notebook
How do I enable the wireless switch on a Gateway mx8711
HI there,
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page. Another source of reference for networking your computer is the Gateway Notebook Networking Guide. Quick reference:
Hope this helps you out.
TheSelkie
Jul 21, 2010 | Gateway MX8711 Notebook
On sound
for no sound issue on your notebook .......
step1. check the volume button on the notebook if its not working then shutdown the notebook and remove the battery from the notebook and then press and hold the power button for 4-5 sec and the connect the battery back to your notebook and restart the notebook
Jun 13, 2010 | HP Compaq Presario C500t Notebook
Powering on the laptop
Remove the Battery from the Notebook and disconnect the AC Adaptor. Press and hold the Power button on the Notebook for 30 seconds.
Connect the AC Adaptor to the Noteobook and to a different wall outlet then press the power button to turn ON the Notebook. If not then insert the Battery pack in the Battery compartment of the computer then press the power button to turn it ON. Make sure that the Battery is fully or optimally charged.
If performing the above mentioned steps didn't power up the notebook nor the power indicator glows on the notebook then the issue is with the power circuit and service will be required.
In this case, contact any service technician to get the Notebook repaired and running.
Nov 03, 2009 | Acer Extensa EX4420-5239 Notebook
HP Notebook not powering up
First, try powering the Notebook by pressing the Quickplay button as if the issue is with the Power Button, it should start.
You need to get the Power Button of the Notebook repaired if the Notebook starts by pressing the QuickPlay button.
However, if the issue is different and the notebook doesnot start by pressing the Quickplay button, I recommend you to try removing the RAM of the Notebook and try with One RAM stick at a time to boot the Notebook and also by checking the Memory sticks in both the Memory Slots.
You can find the required instructions to remove and replace the RAM modules in the Notebook from the Manual of the Notebook which is available through the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions starting from page number 104 of 233 in the Manual.
However, if the issue persists, it can be a Hardware issue for which you may have to get it repaired.
Additionally, I would like to inform you that HP had identified some hardware issues with few Notebooks installed with AMD Processors and is providing free repairs for notebooks purchased and currently available in US and Canada.
You need to get the Product Number of the Notebook which is indicated with P/N and is printed on a white sticker pasted at the bottom of the Notebook.
Check if the Product Number of your Notebook is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If your Notebook product Number is listed in the link provided above and if the Notebook is installed with AMD Processor, you need to contact HP Chat Support and provide the required details and get the Notebook repaired by HP for free.
You can find more information about this repair offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can contact HP Chat Support for DV6000 Notebooks preinstalled with AMD Processor by clicking on this Link.
Hope this helps...
Oct 31, 2008 | HP Pavilion dv6000z Notebook
Trying to find the reset button om a presario compaq 2005 but cant find it and need help
Like in Desktops, there wont be Reset Buttons available for Notebooks.
If you want to reset the Notebook, all you need to do is to press hold the Power button for 6 to 10 seconds so that the Notebook will be turned off.
The same applies for desktops which donot have Reset button or if the reset button is not working.
Aug 21, 2008 | HP Compaq Presario C304NR Notebook
Computers & Internet Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
