SOURCE: paper either just rolls through without printing or won't catch and sits there
Me again. I had to get a repairman to come out and he basically CLEANED the bejeezus out of the rubber roller section that pulls the paper through. Seems alright again. For now... He used a solvent (said lighter fluid was okay for this purpose- because I had some on hand from a friend who uses it for cleaning such thing, and he fixes printers as part of his work). He wetted a rag with the solvent, and wearing rubber gloves, worked those rubber rollers over good. That seems to be the answer.
SOURCE: epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
SOURCE: printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
SOURCE: my epson nx400 getting message
Have you taken out the spacer between the cartridge and its locater handle? Else just try taking the cartridge out and re-inserting. If this fails have you tried powering the printer off, waiting 20 secs, and truning back on.
Hop this helps.
Check
the following:
Paper
type
Load
up to
this many sheets
Plain paper
Approximately
120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper
Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do
the following:
1. Gently pull any jammed paper out from the output
tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson
Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus
NX400. Open the scanner, remove the jammed paper and torn pieces, close the
scanner, and turn the Epson Stylus NX400 back on.
