Question about Sony BRAVIA KDL-52V4100 52" LCD TV
Sony KDL-52V4100 TV turns on for less than a minute then loses picture, why?
Serial # 9051793. Have gone through all of the recommended owner's checks..power off etc. TV turns on, full picture for less than a minute then goes black. No LED lights flashing, steady green power LED stays on.
Posted by Brian Nicoletti on
Sattech
  • 22 Answers
Nice TV ,but, is an LCD . most likely cause may be after long service life the 'Cold Cathode' tubes have begun to grow a carbon track down from the high voltage input . This causes the power supply for that voltage to determine too much load and shuts down . I am surprised you do not see a flashing LED pattern but this does not mean that the condition was communicated to the ECU .
That is a lot of tubes to change at about 40 usd for 10 pieces . It is also a Pain in your seat cushions to disassemble to confirm (ie: delicate connections to undo , mechanical puzzles to solve) I have seen Youtube videos of people converting to LED backlights with very nice results . It is possible but not recommended to change just the bad ones , you will soon have to do the rest anyway .
There may be a shop that does it often and could save $ compared to replacing with LED tv set that size or maybe a shop that converts(not me!)
Luck ... Hugh
Posted on Mar 10, 2017
5 Related Answers
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
Anonymous
  • 556 Answers
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
Anonymous
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
Anonymous
  • 458 Answers
SOURCE: Sony Bravia KDL-52V4100 turns on and displays
light flashes. How Many Times ?
Posted on Dec 31, 2009
I have a Sony 52 inch kdl-52v4100.had a power surge.now tv will not power up
Tv might be fried.Or one of the circuit breakers Is popped. Maybe try a different electrical outlet.
Apr 20, 2015 | Sony BRAVIA KDL-52V4100 52" LCD TV
Resetting my sony KDL-52V4100
Your tv probably has a remote. One of the buttons says "menu" or "settings". In one of those menues will be a reset to factory or default.
Feb 26, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
No picture, no sound display though back light lamps are ON.
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
Problem with sound on sony KDL-52V4100
I think you have a circuit issue not a software issue.
May 02, 2017 | Sony Bravia V-Series KDL-52V4100 LCD TV
How to adjust the convergence on the Sony Bravia KDL 52V4100
Can you please elaborate problem of tv because LCD tv does not have convergence section nor it got any problem of convergence.
Thanks.
Jun 03, 2011 | Sony Bravia V-Series KDL-52V4100 LCD TV
I have a 52" sony bravia MODEL# KDL-52V4100. it comes on but every 3 minutes it shuts off and restarts. have gone through all the timers and settings but still does it. i dont have the remote that came...
Try website like Remotes.com to buy an exact remote to the original remote.Tries tv unplug,replug tv an hour later,the tv will reset itself back to the factory setting,could solved ur problems.
Oct 11, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony BRAVIA KDL-52V4100 52" LCD TV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
