Question about Hitachi Televison & Video
I have a hitachi rc1205, how can i change the source on my tv. There is no button on the actual rc that says source. EDIT: There is no input button either.
Posted by Rebecca on
ray gallant
    Top Expert:
  • Hitachi Master
  • 68,282 Answers
How about input then
Posted on Mar 10, 2017
  • 3 more comments
  • Rebecca
    Rebecca Mar 10, 2017
    There are no labels on the rc so it's completely unclear as to what to press
  • Rebecca
    Here'so a photo
  • ray gallant Mar 11, 2017
    photo is unreadable laying flat other than OK I can not read any of the buttons
  • Rebecca
    Rebecca Mar 11, 2017
    Sorry I'm using a tablet with an awful camera so I can't take a better picture of it
  • Jayden Godtschalk Feb 17, 2019
    What button do I have to press to change the hdmi
How to reset hitachi 51f59a
You can change input using inputs button on remote or the TV button to bring it back to the correct live TV source. Here is your manual: Hitachi 51F59 Operating Manual
Oct 13, 2018 | Hitachi Televison & Video
Changing the input on a hitachi tv without the remote
well if I knew the model number could possibly tell you eactly where it is located , as I do have over a hundred manuals for hitachi products , but anyways look on bottom edge of screen there should be five buttons one of these hould be labeled source , this is the button you want to press , it may take severl presses to get the input you like and the display will show in green what input its on
Jan 06, 2017 | Hitachi Televison & Video
Can anyone help me figure out how to change the source/input.
You should have a button on the remote labeled "input or source". Every push on that button will cycle through different inputs. Some inputs do not show up on the screen unless something is actually hooked up to that port.
Mar 16, 2016 | Coby Televison & Video
Why wont my hitachi remote RC1205 work on my TV, I've changed the batteries
If you changed the batteries and installed the replacement batteries correctly, the remote may have failed and will have to be replaced.
Jan 18, 2015 | Hitachi Televison & Video
Where is the source button on a hitachi CLE-96o control
Click on the image to enlarge it.
Everyting in the RED square is your source buttons.
Depending on which selection you have it on ( Tv / DVD / SAT )
all of the buttons underneith will take you to a different input.
You will need to know which input you have each componet on.
I suspect you are asking about "source" button because thats the one that has your Cable/Dish input. Simply have to look on the back of the monitor/Tv to see which input you have it plugged into.
Jan 07, 2015 | Hitachi Televison & Video
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Nov 07, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi TV turns on but cannot get channels.The blue light and power lite comes on. Changed batteries in remote, still no channels
sounds like a simple input problem, find the input button on the remote or the tv and change the source input until you get a picture,
May 28, 2011 | Hitachi 42 in. Plasma TV
I have a rima dv1320p tv/dvd combo. How do I change the channel to the video 1 or video 2 input?
You actually don't change the"channel", you change the source of the image: from the tv to Video1 or Video2. For that al you need to do is to press the Source button on the case of the tv or the button on the remote. The button might also be called TV/AV or Input or have a square with an arrow pointing in it - depending on the version of the remote. The button cycles thru them so just keep pressing till you get the one you need.
Dec 22, 2010 | Televison & Video
What channel do i use to use the DVI entry?
None, channels are only on the tv source entry. The DVI is just another AV entry, to use it you just select it from the other AV sources.
Jul 05, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi 60V500A Tv changes inputs by itself
sounds like the tac switches on the actual tv which are very hard to get they may be sticking
Mar 21, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
249 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
