Question about iPhone 5c Cell Phones
My iphone 5c makes crackling sound when calling and sometimes no sound when calling . Mic and earpiece are fine working . Tried resetting and all but not fixed . What may be the issue?
  • Anonymous Mar 10, 2017
    When the crackling sound comes i just twist ad squeeze the phone then it fixes but again comes . I am so frustrated bout this . Please give me a solution
John Yarrington
    New Friend:
    Problem Solver:
  • 5 Answers
There's been water damage. Maybe from actual water coming in, contact with it or from you using it in damp places like the shower. What I would suggest is that you try to see if you had get the same result when you're using your headphones and microphone. If it works better with headphones than there's probably moisture on the receiver. If this is the case a bag of rice will always dry out your phone. Put it in a plastic bag with rice sealed shut maybe with two or three bags to make sure the rice is able to draw the moisture out of the phone.
Posted on Mar 10, 2017
    It happens when i use a headphone too . What may be the issue?
5 Related Answers
Anonymous
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
Anonymous
SOURCE: Cannot hear callers/callers cannot hear me/buzzing & crackling sound when connected
try pairing the bluetooth device to another phone, i had the same issue, i used a different phone for testing. it works, so i paired it to my phone and it also works
Posted on Dec 31, 2007
270rexton
270rexton
  • 782 Answers
SOURCE: no sound on skype iphone calls
Skype is a high data demand application, thus require fast internet connection, at least 3G (384KBs) but for best performance HSDPA (up to 3.6MBs) recommended. Thus iPhone 3G (S) you need. You may try Fring (not sure if it's compatible with iPhone).
Posted on Oct 28, 2009
Tim Digibrain
  • 846 Answers
SOURCE: earpiece on iphone not working.
Sounds like the ear speaker connector wasn't connected properly upon reassembly, maybe the ribbon cable is torn. There is a stepby step guide toothat explainshow to properly reassemble the phone: iPhone repair. There are also third party iPhone repair companies that do it for you.
Posted on Nov 08, 2009
Anonymous
SOURCE: LG enV earpiece and key sound not working
go to tools and setting --> sound settings --> keypad volume...see if you see "KEYPAD VOL-EARJACK"...that means that your phone is stuck in EARJACK mode....get a wired ear piece, plug it in, make a call, and then unplug after you end the call....that should resolve your problem...
Posted on Mar 18, 2010
When I get incoming calls I cannot hear
In order to make calls, Microphone access is required. If you check your Microphone settings and see that they are just fine, try plugging in a headset with a mic on it. If you don't have that, try checking the mute switch next to the volume buttons, or the mute button in the call screen.
I am having problems using Bluetooth with my Iphone 5C and can not make calls using handsfree. My phone seems to connect to the car easily, however, when I make or receive calls I can not hear the caller...
It could possibly be the speaker of the phone. there could be dusk in the microphone or when you listen to someone talking. this happened wit my phone.
1helpful
Why do people say they can't hear me when I call them?
Well, there's a bunch of reasons why that could be:
•You speak in a muffled/slurred voice that is difficult to understand when the listener is not looking at you
•Your phone's microphone is defective and need repair/replacement
•you have a case on the 5c that covers one or both of the microphones. There are two mics on the 5c: one that actually captures the intended audio and the other there listens for background noise. What the phone sends to the listener on the other end is a subset of the two microphone sources passed through a complex filter.
The "main" mic is on the bottom of the iPhone while the background sensing mic is on the rear housing between the camera and flash.
•you have debris/dirt in the microphone holes
2answers
Iphone 5c
I'm assuming you have tried the obvious things like turning the volume up? If so, you need to replace the ear piece speaker. Link below to buy the part and video on how to fix. Fairly easy repair.
Earpiece Ear Piece Sound Speaker Replacement Parts for Apple iPhone 5C
Links in emails don't open in new iPhone 5c
Have you tried turning the phone completely off and back on again? Sometime it just needs a fresh start.
press the button at the top and hold for 10 seconds, the slide to turn off. Press the top button to turn on again when it is completely off.
2helpful
Does the Apple iPhone 5C come with the Apple headphones?
No, inside the package the new Apple iPhone 5C will have the Apple EarPods with Remote and Mic. They are less flat than the Headphones. The EarPods are rounder and are inserted deeper inside the ear to ensure a better quality of sound.
1helpful
Earpiece on iphone not working.
Earpiece not working
I have the same problem. By any chance have u fixed the problem since last year? Do you remember what you did?
10helpful
9answers
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Cell Phones Logo
Top iPhone 5c Cell Phones Experts
john h
ADMIN Canada
ADMIN Canada
Kolbrun...
Are you an iPhone 5c Cell Phone Expert? Answer questions, earn points and help others
