Sewing Machines Logo
M
Margaret Ellison Posted on Mar 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adjusting the stitches on White sewing machine 425
R.A. Ellis
Level 3:
  • White Sewing Master 12,731 Answers
  • Posted on Mar 10, 2017
R.A. Ellis
White Sewing Master
Level 3:
Answers
12731
Questions
Helped
2619065
Points
59176
Adjusting stitches how? Are the stitches too short, too long, is the tension off, are there loops of thread accumulating (bird nests), thread pulls out of the fabric, is the top thread not picking up the bobbin thread????
I have a white model 977 tried sewing straight stitch and the stitches are all bunched up tight. Tried adjusting tensions. First time using this machine. Could I of threaded it wrong? Or what?
Sounds like your stitch length is set too short. Lengthen the stitch length to at least 2 or higher. Also, check to make sure the feed dogs are not in the darning position. When darning, the feed dogs are dropped below the sewing surface so their action does not move the fabric. Unless the tension is very, very tight, it should not cause the stitches to be very close together.
You would probably benefit by having an owner's manual. Search the internet, input:
Manufacturer + Model + the word "Manual"
The feed dog moves, but doesn't seem to move the material through
try adjusting the bar that the presser foot is attached to , check in your manual for the instructions to do the adjustment..
1helpful
No manual. how do I change needle position for 1/4" seam on a Freesia 425
When set on a straight stitch using the stitch width button will change the needle position. If you have moved it far to one side you can use the mirror image to shift it to one of 25 positions.
1helpful
Loose stitching underneath
try adjusting the top thread tension and see if that help the loose stitches underneath.
also try changing the needle
and clean under the needle plate and in the bobbin area
Loose bottom stitch
try adjusting the top tension and see if that helps the bottom stitch
here is a free manual for the machine
http://www.singerco.com/uploads/download/1142_white-2999-x.pdf
3helpful
White XL1760 cant find the setting for the straight stitch.....a, b, c????
You can download a manual for your White machine from the Singer website, link is
http://www.singerco.com/uploads/download/1111_white-1760-xl-x.pdf
Here are the relevant pages from the manual:
Straight stitch settings as follows:
stitch length on 2.5 (selector marked with blue arrow)
stitch width on zero (no swinging of the needle) selector marked with red arrow
stitch selector on A - selector marked with green arrow
Generally all sewing machines will have a similar three controls, because all stitches are a combination of moving the fabric forward a certain amount between the needle going through the fabric - the stitch length; and moving the needle from side to side - the stitch width.
And then a stitch selector for different stitch forms such as a blind hem or shell stitch where the needle is going through a series of different moves in sequence to form a special stitch. You still have the width and length controls to vary this formation.
For general sewing machine information www.sewing.about.com is excellent, there is lots of pages on general tips, cleaning, threading up and sewing machine know how. Try this page to start http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machines.--9k/
If you are a beginner, then I'd recommend printing out the instruction manual for your machine and putting into a binder, placing beside the machine, and carefully read from the beginning going through all the instructions to wind a bobbin, thread up, three or four times until you can do it without reading the manual, then practice stitching out each of the stitches your machine does. Buy a cheap exercise book and on each page, write the name of the stitch, staple the stitch sample in and either write down the settings used or glue in a photo taken of the machine controls you used. This way you can quickly flick through and refer to your settings next time. ADjusting the top tension dial will also adjust the stitch formation so read the manual and set the tension dial to the setting it suggests but sometimes you'll need to adjust it slightly to get the stitch looking even (balanced between top and bottom thread), especially for zigzags.
Practice a bit and you'll soon feel much more confident using the machine. Also, refer to the cleaning and oiling instructions and do it regularly, along with changing the needle for each new sewing project, about 4-6 hours sewing time. The needle is the most important part of a sewing machine, always use the right sized needle for the fabric. Refer here for info http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
I hope this helps you with your White sewing machine, there are lots of great sewing machine books on the market too or in your public library to refer to. Also taking beginner sewing classes will really help you learn how best to use your machine. I've been sewing for over 38 years but still enjoy going to a class and learning a new technique from another enthusiast - life long learner!!
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
