Question about PfaFF Sewing Machines
Pfaff quilting machine bobbin stuck
Pfaff powerquilter 16.0 bobbin is stuck
R.A. Ellis
  • PfaFF Master
  • 12,731 Answers
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Posted on Mar 10, 2017
5 Related Answers
Anonymous
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
Page Gettman
  • 30 Answers
SOURCE: Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Posted on Jan 24, 2009
Anonymous
  • 6 Answers
SOURCE: teach me how to thread my new machine
1. Do you have the sewing machine manual?
Posted on Mar 24, 2009
bargainbox
Hassy
  • 1388 Answers
SOURCE: I have purchased a Pfaff 18.8 Grand Quilter
Speak to the Pfaff dealer where you bought it and tell them....they will probably arrange a replacement with little fuss.
Posted on Aug 27, 2009
Testimonial: "Thanks for your prompt response: Both I and my dealers have been working together No luck but thanks for trying"
Robbie Brewington
  • 255 Answers
SOURCE: pfaff varimatic 6091 sew a rag quilt with jean and
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Posted on Feb 10, 2010
Spool thread jammed up in the bobbin area. took tweezers and got what thread I could out. I still think there's a thread that's keeping it for working. How do I get to it on a Pfaff creative 1475cd.
Hello Roz
If there is some thread caught in the bobbing case area, the best solution is to remove the bobbin case and disassemble the bobbin case area. This is shown on page 16 of the manual. If you need a manual it is available free on line at this link http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative-1475CD-manual-1-EN.PDF
Please do give me a thumbs us if this is helpful, otherwise please send me a message with the challenge.
Happy stitching
Sewingirl/
Jun 07, 2018 | PfaFF Sewing Machines
The bobbin case is stuck and will not move on my 1536 Pfaff
Could be you are using the wrong bobbin size. May need to be pried out of the bobbin case
Feb 03, 2018 | PfaFF Sewing Machines
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Manual Pfaff 1212
is there thread involved in the bobbin being stuck?
Apr 05, 2012 | PfaFF Sewing Machines
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
236 people viewed this question
Top PfaFF Sewing Machines Experts
Richard Schabler
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
