Epson Stylus Photo 820 InkJet Printer Logo
A
Anonymous Posted on Mar 09, 2017
Epson stylus photo 820 printer works great on Laptop w/Vista. However will not print from laptop w/Windows 10. Gives message printer in error state or state of error.
Robert john
Level 3:
Master:
  • Epson Master 301 Answers
  • Posted on Dec 31, 2020
Robert john
Epson Master
Level 3:
Master:
Answers
301
Questions
10
Helped
265936
Points
1441
The Epson printers are famous as there are lots of features with the quality of printing. Being so good at printing, these printers can also face technical glitches as well as have technical faults. The faults and glitches are mostly in the form of errors. There are various errors that these printers are going to face. One of the most common errors that this printer is going to face the Epson Printer in Error State Windows 10.
The printer in an error state signifies that the printer is unable to print. This error can occur easily when there is any piece of paper or paper clip that is stuck in the areas of the printer. This error can also occur when if any part of the printer is not working correctly as it used to.
In order to resolve this Epson Printer in Error State Windows 10, you need to follow the steps written in the blog. There are sure going to help you resolve the error.
Check below if you want an immediate & expert-written solution.
Blog : Epson Printer In Error State Windows 10
Epson stylus photo 820 printer works great on Lapt - b6633326-5dc0-4a4d-8b6c-8e85a1654448.jpg
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Oct 13, 2008
SOURCE: I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Anonymous
  • 1179 Answers
  • Posted on Jan 25, 2009
SOURCE: How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Anonymous
  • Posted on Feb 27, 2009
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Anonymous
  • 700 Answers
  • Posted on Apr 17, 2009
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Jun 28, 2009
SOURCE: Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
2answers
I have an epson stylus photo r300 and epson stylus cx3200 printers which were working great with xp operating system. I now have a laptop with vista operating system, when i install the printer software...
Try going online to Windows Update and see if there is an update,same for epson's site.Also look at Microsoft's XP knowledge Base and search for this issue.My guess is the drivers for the printer needs updating.Good luck
2answers
Install epson stylus photo 820 printer
Hi
you can get the software driver at www.support.epson.com
just select the printer driver and download it//
Can't download printer software
The Vista 64bit driver can be found here There's also specific installation notes - one states not to use the CD provided if it does not say Vista on it!
Get an error message when trying to print test page
Please uninstall your printer then reboot the computer. Make sure your printer is switched off, then insert your printer installation disk and follow the instructions. Do not turn the printer on unntil asked to.
Please post a new comment if you need further assistance.
203helpful
7answers
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
I cannot get the software to work for my 820 on my new vista. Any suggestions
If you read the link, you will see vista already have a driver built in http://www.epson.com/cgi-bin/Store/support/supAdvice.jsp?BV_UseBVCookie=yes&noteoid=86150&type=highlights
the statement below was cut from the Epson website -
Drivers are included with Windows Vista. Just connect your Epson product to your computer and follow the on-screen instructions that Windows Vista displays to guide you through driver installation.
Epson Stulus photo 820
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
