Question about Nortel Lands Phones
With my company's Nortel business phone, I'd like to change the rings to 4 before it transfers to voice mail. Any suggestions?
Posted by Kim Robertson on
5 Related Answers
Anonymous
  • 201 Answers
SOURCE: Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Posted on Aug 21, 2007
Anonymous
  • 28 Answers
SOURCE: no ring,goes directly to voicemail
your phone is on 'do not disturb mode'. call your provider and ask how to shut it off. for telus mobility it is *79 then hit send
Posted on Sep 02, 2008
blz131356
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Posted on Feb 09, 2009
Anonymous
  • 9 Answers
SOURCE: I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
Posted on May 21, 2009
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
No voice mail on my nortel phone
sounds like your forwarding is not set in programming for no answer or busy.
Aug 22, 2012 | NorStar T7316E Corded Phone
When outside people call us from a touch phone, it asks them to dial
Hi there
The Nortel and any other of PBX come with the voice mail, and you configure the voice mail as a phone ring.... If you can not pick up your phone in 3 time of ring then automatically your phone transfer on Voice mail and there as you setup..........In voice mail it asked which number you want to call and say the details Example: - Dail 1 to Drawing Room Dial 2 for Dinning Hall Dial 3 for Bed Room..
You just configure you voice mail system and solve you problem.
Thanks
Mar 22, 2012 | Nortel T7316E 2-Line Corded Phone
Press GRTG
Press GRTG again
press 1 then ok
Press REC.
Hope this helps
May 18, 2009 | Nortel Business Series Terminal T7208 -...
Norstar Flash
phone is not programmed for forward busy no answer.
Feb 06, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Mailbox inactive
You can have this phone on one of many different Nortel phone systems and you can also have different voice mail systems. If your voice mail is old and based on a hard drive it could be failing. Chances are your voice mail is the problem. This can get very complicated for someone not familiar with phone systems and voice mail. I would highly suggest looking for a local phone system installation company that can come out and troubleshoot the problem. If your voice mail is 10+ years old and based on a hard drive you may want to replace it regardless instead of wasting time paying a tech to find an intermittent problem. A hard drive running 24/7 for 10 years will not las much longer anyway.
Nov 16, 2007 | NorStar M7324 Telephone
It rings 20 times before voice mail comes on and they can leave a msg.
You are asking questions about your Toshiba phone system and the voice mail system attached. You could have one of several different Toshiba phone systems and several different voice mails.
The system has timers for things like "No answer transfer timer" and also rules for what it does at that point. (transfer to voice mail box, transfer to voice mail branch, transfer to the operator.. etc..) It can get very complicated. Most likely you are just dealing with the no answer transfer timer for your specific phone port but even just changing that can be very complicated. Many Toshiba phone systems need to be programmed from a computer using specific software. If you do not have someone in the company that knows how to make simple changes to the phone system you would need to get a phone system installation company to make the changes. Hopefully you know the company that installed the system??
Nov 09, 2007 | Toshiba DKT-2010 Corded Phone
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Lands Phones Logo
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
