Question about Alphasonik Car Audio & Video
Need a wiring diagram for a EQ peq 7B alphasonik
Posted by Ralph Ramirez on
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
Posted on Dec 11, 2007
Anonymous
  • 77 Answers
SOURCE: diagram for [ioneer car equalizer
greetings. with most stereo manufacture's you can get all the information you need from thier website, in this case check out http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
hopefully you'll be able to find it here.
Ryan
Posted on Feb 18, 2009
jimbo03
SOURCE: i have a zapco model
The plug consists of a 7 pin plug which contains a ground, a hot lead for the PEQ itself, a neutral for the PEQ, and a hot and negative for each L and R channel, respectively. I had mine changed to RCA's years ago by a local shop, then soldered the connections myself after the proper connections were changed at the shop. I now have the signals changed into a Symbi-Link Transmitter/ Reciever System (unbalanced to balanced inputs) and am able to de-tune the PEQ and still get more output. It's fun... Hope the info helps.
Posted on Jan 16, 2011
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: i need a wire diagram for an alpine 3210 graphic
Good day!
I got it with fee.
Just click this open link:
http://www.tradebit.com/filedetail.php/133048118-alpine3210-graphic-eq-service-manual-schematics
Or this direct link to order:
http://service-and-repair-manuals.tradebit.com/contact.php
I hope this link could help you.Thank you for using fixYa.Good luck.
Posted on May 09, 2011
plasmadis
SOURCE: need the wiring diagram for
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Posted on May 27, 2011
How can I connect this EQ on my mustang I don't have amplifier right now only the EQ
an eq is kind of like an amplifier anyway it boost the sound and tailors the sound to your taste. Your eq should have a wiring diagram on the bottom or top of the unit. Your factory radio should have a wiring diagram on top or bottom of it as well. So all you have to do is match left + to left + and right + to right + etc. It's really easier than you think. You just have to pay close attention to the diagrams.
Feb 03, 2015 | Audio Players & Recorders
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email [email protected]
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
Where can i find a wiring diagram for these subs??
Here is a link for wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Your speaker is a DVC so follow the Dual Voice wiring as it is universal set up.
Sep 19, 2010 | Alphasonik PSW112C Alpha 100 Series 12"...
I have a zapco model PEQ board and i need the cable/wire wiring instructions can you help me?
Jun 01, 2010 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
How to wire pma100 voltmeter without amp
Hey dude- if you dont figure out how to wire that thing up -i need one for my pma-2500a i got it from the pawn shop yo for 150 bucks !!!!!!! shwinggggg its a beast 1600 rms at 4 ohms bridged - what a steal but yea i need one so lets make a deal dude !!!
Jun 06, 2009 | Alphasonik PMA1000HCA Car Audio Amplifier
Car Audio & Video Logo
193 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
