Question about XO Vision Car Audio & Video
How to set time on xo vision xod1752bt - XO Vision Car Audio & Video
Posted by Daija on
5 Related Answers
Anonymous
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
Anonymous
  • 3 Answers
SOURCE: XO Vision MP3 player-problems downloading TV shows
Um hey, I have a Lyra MP3 player, I can't download videos but I have gotten music on it. When you download your music, it goes to a certain folder in your computer, it's up to you to find it. All that I did was copy/paste that to your MP3's folder. If that doesn't work I am really sorry.
Good luck,
Shannon
Posted on Jan 02, 2008
Anonymous
  • 216 Answers
SOURCE: XO Vision GX 1236
With solder.
[email protected]
Posted on Mar 08, 2008
Anonymous
  • 61 Answers
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
Posted on Mar 06, 2009
Anonymous
  • 3 Answers
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Posted on Apr 06, 2009
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
1helpful
How do i get the xo vision gx2146 to play threw my stereo speakers
Pull up the menu screen and scroll through until you come to FM transmitter. Select FM transmitter and scroll through to select a radio station(88.1, 89.1, etc). Select the station. Now, tune your vehicle stereo to said station. Enjoy.
1helpful
Replacement screen for xo vision 1742 deck
Model LCD 7'' :Innolux AT070TN07 + Touch panel (unknow)
Is there any way to just order the audio/video inputs for xo vision xo27702 monitor
is there any way to just order the audio/video inputs for xo vision xo27702 monitor
Setting correct dvd region
Contact Xo Vision for region codes and ask how to input them...
Xo vision dvd player
hi there
4answers
XO Vision XOD1740BT
ground the brake . all u need to do.
1helpful
2answers
Car Audio & Video Logo
Top XO Vision Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Relax
Relax
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
