Only used one time.
Green washing light just blinks.
Tried circuit breaker for 1 minute, 5 minutes, 30 minutes.
Tried putting into maintenance mode (rinse cycle and hold the two buttons) It does make the washing light go solid but it never cycles through to the next cycle, unless I press start/cancel again.
SOURCE: my dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
SOURCE: I have a new Frigidaire
It should still work pretty well but you probably can't use the high temp wash because it will take too long for the dishwasher to heat up the water enough to satisfy the high temp washer thermostat. If the thermostat's calibrated closing temperature isn't reached the dishwasher will just keep running. One thing you should do to improve washing results is to run the nearest tap (probably the kitchen sink) until the water is at it's hottest and then run the dishwasher so the first fill will be hot rather than warm.
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
SOURCE: Our Frigidaire Dishwasher buttons stopped working.
You will have to replace that selector switch
http://tclaundryrepair.com/
Hi sallysue5928 - How long was the delay start set to? Typically the delay time selected will be displayed as 30, 60, or 90 minutes or 2 through 14 hours. However, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful then unfortunately you will have to wait till the time of the delay start cycle that was selected.
