Canon MP610 Photo All-In-One Printer Logo
Kathy Hanslow Posted on Mar 07, 2017
Where can i buy a new print head for mp610 - Canon MP610 Photo All-In-One Printer
1 Related Answer
kjhbewfgdbgr
Simon
  • Posted on Dec 15, 2014
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Canon MP610 and it will not print or copy in black and white have changed cartridges and cleaned.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
19helpful
How do you remove/clean/replace print head on pixma mp610 BK nozzle blocked.
Try this :
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
17helpful
2answers
I replaced the cyan ink cartridge. The printer accepts that the cartridge is full but prints with no blue. I bought another new cartridge and have the same problem.
It sounds like you need a new print head. You can find them online for around $75.00 each. I've had very good luck with Precision Roller. Do a google search for "canon mp610 print head".
3helpful
I have a canon mp610 printer. the yellow coulor is not coming through, any ideas , otherwise printeris great
The print head is clogged.Try unclogging with cleaning process in maintenance mode.If not help you need replace the print head.It's part number is QY6-0067
1helpful
2answers
The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
2helpful
2answers
To buy or not to buy canon or compatible inks
The generic inks don't hurt your machine at all, but I find that the colors arent as good and bright as the Canon inks.
1helpful
Error: print head not installed. Install print head
Make sure the contacts on the carriage assy. where the printhead sits are clean also. If your printer is still under warranty it will be repaired free of charge, if not, it sounds like you may need a new printhead. The part number for the printhead is printed on one side, it's always a qy6- number followed by 2 sets of 3 numbers each.
old marine
old marine
ZJ Limited
ZJ Limited
