Is there anything inside? You should not run an empty microwave. That said, it shouldn't really spark. Is there anything metallic inside? Any metal or foil can cause sparking or arcing. If you use a bowl with a pattern which has a gold or silver painted rim this can have a similar effect. If nothing like any of the above then I suggest you refer it back to where you bought it as there may be a problem with it.
It might be the appliance isn't properly grounded or it might be it is faulty or it might be there is something inside that is unsuitable.
Microwave ovens should not be operated with nothing inside and only suitable containers should be used to hold food for heating. Cups or plates with gold painted rims and metal containers and those containing metal are likely to cause a veritable electrical storm inside.
SOURCE: Need Mount for Goldstar MV1526W microwave
You can contact LG via their world portal here: http://lgservice.com/
SOURCE: microwave no power
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
SOURCE: power on a MV1526w Microwave!!
Yes, the display should always be on when plugged in.
fuse should be easily found in the back by the power cord. It looks
Hope ya fix it!
SOURCE: Goldstar MV1526W over the range microwave
We actually have the service manual available at our site:
http://www.microwavedisplay.com/mv1526_sm.pdf
That should help you or a friend check and diagnose it.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: light bulb for Goldstar MV1526w
Your best bet is to remove the old one and match it up at the store.
You can usually find them at local appliance parts stores, home centers and home improvement stores, as well as places like Wal-Mart.
Many models use a halogen lamp. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you'd rather order it first, call Goldstar / LG at 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
