Cell Phones Logo
Meredyth Sawyer Posted on Mar 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Konka U3 and I can't find the adjustment for the hearing volume. I found the volume for other things like ringtone, message and keypad but what about the volume in your ear?
da surgen
Level 2:
  • Expert 96 Answers
  • Posted on Mar 05, 2017
da surgen
Expert
Level 2:
Answers
96
Questions
0
Helped
72732
Points
194
Call anybody in your phone. as soon as you hear ringing start hitting your volume all the way up.
How do I increase the ringtone volume on my sp10 konka mobile...I can't hear it call and it is on full volume
Hello good day,
So very simple,
you need to be in an active call to do this,
so make a call then during the call making you we need to use up and down button (key) to increase the value , this button(key) is beside the phone on the direction pad to increase or decrease the volume
However, this is how to solve the problem on call either on incoming call or out going calls
Thanks.
Hi, it's Karin again from South Australia =SA Thanx for this free Service, is this open 24/7? But where can I get a free User Guide showing me all about Konka U3 Flip Phone please? Karin
in your browser search bar type in --user manual for konka u3 flip phone --- and if there are manuals available free ones will show up as pdf version for download
3answers
When i ring someone or they ring me they having suddenly become very quiet and hard to hear but my ringtone and message tone are still at the same volume, i've adjusted the volume level to highest and...
Hi here are some solutions hope it can be helpful..Go to the setting on the menu.make sure that what profile setting specifically the volume the ringtone either text or call that was personalized was the one that was activated..
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
2helpful
2answers
I have a LG420G TracFone and the ringtone for phone calls is nice and loud, but, any ringtone I set for text messages coming in make no sound at all? I keep missing important messages.. I need to hear my...
You're right, the book that comes with it is worthless. Have you found the volume buttons? On the side of the phone opposite of where the charger goes. You can push in the middle and also up or down to make it louder. I can't even figure out how to hear different ringtones. lol
Oct 08, 2010 • Cell Phones
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Message ringtone on my phone isnt loud enough.
you have to change your tone or loud tone and must reset the volume of your message tone
4helpful
Samsung j 700 How do I turn off keypad tone ?
My problem was with a samsung j 700. I found a volume uitton on the side of the handset, which I turned fully down, and this did not affect the volume of the ringtone.
2answers
SAMSUNG CELLULAR
Try to reset the factory setting & check the volume.
Some ringtones are defaultly low volume ,so try to change with new ringtone.
Not solved,then check with the authorize service center for Speaker Check.
Top Konka Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Don A
Don A
Are you a Konka Cell Phone Expert? Answer questions, earn points and help others
