Question about Tablets & eReaders
1st gen kindle won't turn on
Kindle is fully powered on screen saver. Have slid and held power button for up to a minute & still won't turn on.
Posted by Kim Seeley on
Robert Hogan
    Problem Solver:
  • 28 Answers
The first-generation Kindle won't turn on. You need the help of the experts. Contact Kindle Support number.
Posted on Jun 24, 2020
Josh Whitehead
    Genius:
  • 1,148 Answers
OK my Kindle has done that before..stick on charger and leave it there...it may pop on on its on...OK and it could be on just screen is not ..hold power button down for like forty five seconds..then release power button and as quick as u release push it in one good time and release button..that's a reset for Kindle hopefully like like with mine u will see LCD light up ..good luck
Posted on Mar 05, 2017
Paper white will not respond to touch.
always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Nov 29, 2016 | Amazon Kindle Paperwhite
My kindle turned itself off and now I cant open it. It is fully charged
Reset the Kindle
  1. Press and hold the Power button for a full 40 seconds. After the first 6 to 8 seconds, the screen will go blank, which is normal. ...
  2. After the 40 seconds, release the Power button.
Jul 15, 2016 | Amazon Kindle 3G
My nephews kindle fire hd 2nd gen screen won't light up, need help
First thing to verify is that it is fully charged. You should see a green light indicating that it is charged completely. If it does not come one then, press and hold the power button for about 10 seconds. That may get it to start up.
Apr 24, 2015 | Amazon Kindle Fire HD
When I turn on my Kindle, I can't go to my apps carosel
To turn off the Kindle Fire HD completely, hold the power button down for 2-3 seconds and release. A "Shut Down" button will appear (opposite "Cancel"). Touch that button. Allow the unit to cycle off completely. Wait one minute, then power up again. Your functionality should be restored.
Feb 08, 2015 | Amazon Kindle Fire HD
Frozen screen and now it won't turn off
If your kindle are frozen and won't turn off so, firstly reboot your kindle this is done by pressing the side button minimum 20 to 40 second and screen are blinking so, give the kindle about one minute to start backup.
What to do when Kindle Stuck on the Start screen
Jan 19, 2014 | Amazon Kindle Fire HDX 7
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Jan 11, 2011 | Amazon Kindle Wireless Reading Device
My kindle wi-fi is not working. I went to turn it on and the light came on but stayed at the screen saver screen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
Non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
May 29, 2010 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
312 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
