Question about Time Computers & Internet
`when connected charge light never changes from yellow to green to indicate fully cgarged ,sometimes it is and other time not
How can I tell if my battery is wearing out? Charge light stays on as long as it is connected sometimes it charges and other time doesnot charge light never changes from yellow to green
Posted by Bill M Durall on
Rick Hickerson
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 119 Answers
Just get a new battery!
Posted on Sep 11, 2017
5 Related Answers
Walter H Boehm
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Anonymous
SOURCE: nokia 6500 classic charging problems
I have had exactly the same problem, and have replaced both the charger and the battery.
I think the problem lies in the contacts between the charger and the bayonet and the battery..
Soooo
I put a couple of peices of folded paper behind the battery, making a very very snug fit.
then, (this is a bit fiddly)
i carefully folded a slim peice of paper to wedge behind the charger pin and the back of the bayonet, so the pin is pushing against the front of the bayonet.
( to do this, position the paper over the pin and push into the socket at the same time.)
works like a treat :)
if you had exactly the same problem, it will be due to the charger wobbling around about the socket.
this ensures a tight fit and means it maintains contact all the time.
good luck, and i hope you haven't started to tear your hair out quite yet.
Posted on Mar 23, 2009
Anonymous
  • 214 Answers
SOURCE: I cannot charge my Samsung L210 digital camera
it has a technical problem you should go to a person who repairs
Posted on Aug 23, 2009
MEDIC604
  • 13 Answers
SOURCE: both green and yellow light stay on and batteries
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Posted on Nov 24, 2009
Fred Yearian
  • 5603 Answers
SOURCE: why my 28v doesn't fully charge
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
Posted on Nov 26, 2009
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Dec 01, 2017 | Green Cameras
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
How do i know my kindle is fully charged
It is supposed to turn green when fully charged. There is also a battery charge indicator on screen.
http://www.amazon.com/gp/help/customer/display.html?nodeId=200728630#battery
Jan 19, 2012 | Amazon Kindle Wireless Reading Device
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Computers & Internet Logo
129 people viewed this question
Top Time Computers & Internet Experts
Ross Keen
Marvin
Marvin
Vernon Taylor
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
