It is doubtful cleaning the filter and using Dettol will have caused any problems.
I believe it was quite common to have a programme where the washer stopped mid-rinse before pumping out the water in order to reduce creasing of the clothes. The programmer would be advanced when it was convenient to do so and the rinse cycle would continue and finish with the final spin.
I suggest you read the instruction manual before deciding whether there is a fault or not...
Testimonial: "Thank you Vernon, but the machine stops after taking some water in and does not finish the programme. Then we put the drainage programme which also pauses after taking out some water. After three times of putting the drainage programme the machine empties and the drainage cycle finishes."
It would be worth checking the pressure switch is working and the tube and inlet into the tub is clear. Possible the Dettol moved some sediment around and caused a blockage. The tube and pressure switch is how the brain knows how much water is in the tub.
Unfortunately if an old sock or something is floating around in the tub causing a blockage the drum will have to be removed to gain access.
If all else fails it would seem the controller is at fault.
Thank you!
